CJ7 Heater Core Plenum/housing removal - JeepForum.com
post #1 of 9 Old 12-01-2013, 04:50 PM Thread Starter
danfrye
1978 CJ7
Swapping my Heater core plenum/box w/ actuators into a newer tub. But for the life of me I cannot find a nut, bolt or screw under the dash to take it apart. Are they suppose to be taken apart from the firewall side? Note: this jeep has had lots of fab work so... not sure if they covered up the nuts and bolts.
danfrye is offline
post #2 of 9 Old 12-01-2013, 05:14 PM
lucdog
1980 CJ5
4 nuts on the engine side of the fire wall.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 9 Old 12-01-2013, 05:19 PM
gainesee
One directly behind the valve cover and three around the battery tray area
gainesee is offline
post #4 of 9 Old 12-01-2013, 06:06 PM
Renegade82
1982 CJ7
Look for (4) 1/4" studs with a nut and probably a star washer on them.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #5 of 9 Old 12-02-2013, 12:58 PM Thread Starter
danfrye
1978 CJ7
Thanks guys. Found the bolts. Some old fab work covering up one of them... Nothing a little grinding cant fix though. Thanks again
danfrye is offline
post #6 of 9 Old 12-02-2013, 01:07 PM
DucST4
DucST4's Avatar
Now would be a good time to install a Chevy Blazer fan motor. Huge increase in air flow. And a low dollar project that has a good return.
I found it a ton easier to remove the passenger seat to get the box installed
DucST4 is offline
post #7 of 9 Old 12-03-2013, 05:09 PM
Renegade82
1982 CJ7
Agreed. A $22 motor and some labor to enlarge the firewall hole that's there now.
post #8 of 9 Old 12-04-2013, 12:11 PM
Blakescj7
if youd even call it labor, took less than a minute with a high speed rotary file. Oh and if you do the upgrade i got mine from a 77 blazer at oreillys. if it has a heat sink collar on just slide it off before you grind the hole to keep from making the hole too large. then just slide it back on after its throught the fire wall.
Blakescj7 is offline
post #9 of 9 Old 12-06-2013, 10:38 PM Thread Starter
danfrye
1978 CJ7
Okay... sounds like a plan... I'll look into the fan motor. Thanks again for the tips
danfrye is offline
heater box , heater box swap , heater core
