CJ7 headlight issue. PLEASE HELP!! - JeepForum.com
post #1 of 8 Old 12-16-2013, 10:37 AM Thread Starter
jdmillenbach
1978 CJ7
About a week ago with no warning the driver side headlight on my 1984 CJ7 decided to go out, not an unusual thing. Where the problem starts is that I replaced the light and the problem persisted, however, when you turn the high beams on, voila, both lights work just fine. The wiring (that's visible at least) seems A-ok and none of my electrically oriented friends can find an issue with it. Has anyone had an issue like this or have possibly heard of a fix for it??
Any help would be hugely appreciated.
Thanks everyone and HAPPY HOLIDAYS!
Every tool is a hammer, except a hammer, that's a chisel... -Richie-
jdmillenbach is offline
post #2 of 8 Old 12-16-2013, 10:51 AM
Spieg8
1984 CJ8
In a factory configuration, low beam for both headlights are powered by the same wire (daisy chained together).
If the driver side is out but the passenger side works, the problem is either the light itself (swap headlights to test this), or the connector/contact is bad.
Bad contacts in the connector are pretty common. Sometimes just cleaning the corrosion off will help (fold up a piece of emery cloth small enough to fit in the slot). If not, they are pretty easy to replace.
Hope that helps.
Spieg8 is offline
post #3 of 8 Old 12-16-2013, 11:47 AM
sickcj978
I had this same problem with my 84 and I got pissed one day and punched my horn button lol and the light came back on I don't know why but it still works I think the connector on the light was bad
sickcj978 is offline
post #4 of 8 Old 12-16-2013, 11:57 AM
vinnyabs
1983 CJ7
I also had it and thought connector. Jewelry file to contacts and worked for a while then went out again. Out of frustration took both buckets out and removed ground screws to inside of grill sanded and reconnected. No more problems and my yellow lights now look like HID. Get flashed often by oncoming drivers
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #5 of 8 Old 12-16-2013, 12:23 PM
Mlaughlin8
1980 CJ5
Try the high beam switch! I found that my foot switch was bad due to a bad connection
Mlaughlin8 is offline
post #6 of 8 Old 12-16-2013, 04:25 PM
Spieg8
1984 CJ8
A faulty dimmer switch will affect both headlights, not just one.
Spieg8 is offline
post #7 of 8 Old 12-16-2013, 05:46 PM
turbogus
1978 CJ5
Good idea cleaning up the ground wires, I've gone the extra step and tied the grounds to the negative battery terminal. Food for thought as they say.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #8 of 8 Old 12-23-2013, 11:04 AM
Mlaughlin8
1980 CJ5
You are correct! Once I fixed the dimmer switch I found that the low beam bulb was burned out on one the headlights
cj7 , electrical , lights , wiring
