CJ7 gas meter - JeepForum.com
post #1 of 21 Old 02-26-2013, 10:23 PM Thread Starter
Jclilk
CJ7 gas meter
Hey, guys i got a problem with my gas meter on my speedometer, I changed the speedometer thinking the gas meter was busted than i changed the sending unit but still the meter doesnt move. Any advice? on what i can do to read how much gas i got please help!! ive been driving without reading gas for the past 4 years. and yeas ive been strainded multiple times
Jclilk is offline
post #2 of 21 Old 02-27-2013, 02:58 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I would check to see if it's getting power. It could be the fuse is blown.
And always check your grounds
John Strenk is offline
post #3 of 21 Old 02-27-2013, 05:54 AM
Ivehad4
1978 CJ7
You'll also likely need to "calibrate" the sending unit. A process that requires bending the float wire until the gas level and the gage agree.
1978 CJ7 304/T150
1959 Willys CJ5 F4/T90
1995 XJ 4.0
1998 TJ 4.0
Ivehad4 is offline
post #4 of 21 Old 02-27-2013, 11:29 AM
waterdowg
Does your Temp Guage work?
waterdowg is offline
post #5 of 21 Old 02-27-2013, 04:13 PM Thread Starter
Jclilk
wheres the fuse for that?
Jclilk is offline
post #6 of 21 Old 02-27-2013, 04:14 PM Thread Starter
Jclilk
i bught the mopar one for the 20gallon tank so i really dont think i have to
Jclilk is offline
post #7 of 21 Old 02-27-2013, 04:16 PM Thread Starter
Jclilk
yea my temp works but i relocated it onto the side of the glove box with an auto meter, so it doesnt work from the speedometer anymore
Jclilk is offline
post #8 of 21 Old 02-27-2013, 04:31 PM
Noplainsdrifter
1974 CJ5
This is your problem, IIRC, they are tied together somehow. They are both on the same circut. I just remember that I had to replace both to get the gas guage to work.
It's a Jeep Thing, Chrysler Doesn't Understand!
Noplainsdrifter is offline
post #9 of 21 Old 02-27-2013, 07:05 PM
dg6772
I believe on the back of the unit there is a flat jumper from one guage to the other.... may be missing or if one guage is shorted the other would or could be affected.
Just a thought
From Dave G. in Muskegon
dg6772 is offline
post #10 of 21 Old 02-27-2013, 09:16 PM Thread Starter
Jclilk
IIRC? so what should i do cause my the temp works perfectly
Jclilk is offline
post #11 of 21 Old 02-28-2013, 02:07 AM
John Strenk
1976 CJ5
fuse is in the fuse bog labeled IGN.
did you click on any of the link in my signature?
post #12 of 21 Old 02-28-2013, 09:11 AM
Noplainsdrifter
1974 CJ5
IIRC, If I Recall
You said that you relocated the temp gauge using a aftermarket gauge, right? The one next to the gas gauge doesn't work, correct? That is the one I'm referring to. Both the gas and temp gauge in the speedo cluster are tied to together, I think if there is no power to the temp gauge, the gas gauge won't work either. At least that's how my 74 works.
post #13 of 21 Old 02-28-2013, 10:14 AM
John Strenk
1976 CJ5
IIRC That's how they all work on these years.
(If I Recall Correctly....)
post #14 of 21 Old 02-28-2013, 10:17 AM
Noplainsdrifter
1974 CJ5
I was close, I still can't recall much... Getting old
post #15 of 21 Old 02-28-2013, 11:47 AM
stroked383z28
1976 CJ5
Not how it works. The fuel gauge gets 12 volts first and then feeds voltage over to the temp gauge. The fuel gauge will work regardless of whether or not the temp gauge is present. The problem could be one of several things. You will need to check the following things to narrow it down.
1. Check you are getting 12 volts at the red wire connected to the fuel gauge. (I terminal)
2. Check that the speedometer housing has a good connection to ground.
3. Check that the gas tank sending unit has a good connection to ground.
4. Check that the resistance on the pink wire connected to the fuel gauge is appropriate for the amount of fuel in the tank. 10 ohms full, 73 ohms empty. (S terminal)
If that all checks out then it would be a problem with the gauge not grounded to the speedometer housing or the gauge itself.
76 CJ5 Renegade, 304, T150, 3.54 gears, 30x9.5 AT's
stroked383z28 is offline
gas gauge , gas pump
