CJ7 Fuel Line - JeepForum.com
post #1 of 16 Old 03-16-2013, 01:21 AM Thread Starter
DYontheForum
1981 CJ7
CJ7 Fuel Line
Hi I have an 81 Cj-7 and I am in the middle of a frame off of sorts. Anyway I am ordering my fuel/vapor line stuff and need to know what sizes of hard lines I need.
Thanks
I order the pre made brake lines and I wasn't impressed, they were very long.
DYontheForum is offline
post #2 of 16 Old 03-16-2013, 02:18 AM
BagusJeep
1981 CJ7
These are the original routings.
You can do them both in 5/16" though originally the return line was slightly smaller.
It often comes in 25' rolls for around $20 so if you are a real cheapskate you could just about use one roll if you have a tank vented through the cap, otherwise you need two rolls. The zinc plated steel is $20, the stainless is nearer $60. The only joins for which you need nuts are at the fuel pump and carb. You may consider buying or borrowing a flaring tool to get a nice flare on the ends and some proper clips to hold the line on.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 16 Old 03-16-2013, 02:58 AM
dg6772
I just stumbled across some, New, on ebay.
You could check those
From Dave G. in Muskegon
dg6772 is offline
post #4 of 16 Old 03-16-2013, 06:35 AM
skizriz
1978 CJ7
I did like Bagus said. I used a 25' roll of PolyArmor in 5/16 for my fuel and return.
I used 1/4 for my vent line.
Total cost was about $40 for both rolls.
Sent from my iPod touch using JeepForum
skizriz is offline
post #5 of 16 Old 03-16-2013, 11:22 PM Thread Starter
DYontheForum
1981 CJ7
I have all the bending, flaring, and cutting tools. I don't need to double flare any of those do I? Speaking of that what is double flaring supposed to be used on?
post #6 of 16 Old 03-17-2013, 12:22 AM
skizriz
1978 CJ7
No need to double flare anything but brake lines.
Look into a line called Poly Armor. It's very easy to work with, you can bend it with your hands without kinking it.
skizriz is offline
post #7 of 16 Old 03-17-2013, 12:57 AM Thread Starter
DYontheForum
1981 CJ7
Where did you get the poly armour from?
post #8 of 16 Old 03-17-2013, 04:24 AM
skizriz
1978 CJ7
Any auto parts store should have it. Costs a little over twenty bucks for a 25' roll. Lasts ten times longer than steel.
skizriz is offline
post #9 of 16 Old 03-17-2013, 09:29 AM Thread Starter
DYontheForum
1981 CJ7
Thank you very much sir.
Do you know where I can get all the bolt on clips that hold the lines to the frame?
post #10 of 16 Old 03-20-2013, 08:11 PM Thread Starter
DYontheForum
1981 CJ7
I can't find poly armor anywhere locally.
post #11 of 16 Old 03-20-2013, 08:21 PM
Brewski
http://www.autozone.com/autozone/acc...er=198103_0_0_
Comes in what size you need. Great stuff and as said very easy to bend.
Brewski is offline
post #12 of 16 Old 03-20-2013, 08:22 PM
skizriz
1978 CJ7
http://shop.advanceautoparts.com/web...008%7CL3*15690
You can order it online from Advance Auto and have it delivered. Look on retailmenot.com for some sweet discount codes also.
skizriz is offline
post #13 of 16 Old 03-20-2013, 11:41 PM Thread Starter
DYontheForum
1981 CJ7
Thank ya sir. So I can use 5/16 for all of the fuel lines?
post #14 of 16 Old 03-21-2013, 05:26 AM
lucdog
lucdog's Avatar
1980 CJ5
You can, but I wouldn't. The return is 1/4", so is the fitting on the return on the filter, and at the tank . Yes a 5/16" connecting hose will work, but it's not the correct fit on the fittings.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #15 of 16 Old 03-21-2013, 01:29 PM
skizriz
1978 CJ7
That's the size I use for both. It works fine.
skizriz is offline
