Cj7, FSJ N/T D44's install-spring outboard question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cj7, FSJ N/T D44's install-spring outboard question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteinjager TJ tube doorsAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONS
Unread 04-19-2014, 11:24 AM   #1
CutterN55
I have a set of Wagoneer 44's I have torn down and am rebuilding.
I am cleaning them up now and getting ready to paint, then assemble with regearing. 79 NT Waggy front (maybe put in a spartan) 89 NT waggy rear with a true trac. 4.10 thick gears. SUA, with waggy steering linkage.
I am currently planning on outboarding the front, haven't decided on a shackle reversal or not at this point...is it worth the hassle?
Next question...outboard the rear as well or just relocate the perches? Will there be a difference in handling improvement if I were to outboard the rear or not?
Thanks
Semper Fi! www.militaryjeepers.com
86 CJ7 258/Np435/D300/Waggy D44's
CutterN55 is offline   Reply With Quote
Unread 04-19-2014, 03:37 PM   #2
John N
1981 CJ8
Just move the rear spring perches on the axle. On the front, I'm not a fan of shackle reversals...other opinions will differ I'm sure. Any change in suspension will change handling, but will also affect other things. A lot depends on how you use your Jeep if it will be good or not.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline   Reply With Quote
