cj7 front spring hanger? - JeepForum.com
post #1 of 7 Old 10-10-2013, 09:23 PM Thread Starter
napaguy
I was looking at the front spring area of a 1976 cj7 frame I just bought and the distance between the front spring hanger and the rear spring hanger for the leaf spring are different distances when you measure across. . I am trying to wrap my head around that one? what am I missing?
napaguy is offline
post #2 of 7 Old 10-10-2013, 10:17 PM
jeep_boy02
1980 CJ7
Shackle hangers or spring hangers?... talking the distance between left and right or between front and rear mounts of same leaf? the front leaves are skinnier than rears keep in mind, depends on where you're measuring... possible spring out board done by a previous owner? Pics are always helpful and whats the measurements you're coming out with?
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #3 of 7 Old 10-10-2013, 10:37 PM Thread Starter
napaguy
I will get some pictures tomorrow when I have some light
napaguy is offline
post #4 of 7 Old 10-11-2013, 07:18 AM
CSP
You don't need pictures, just a better description of what you're comparing.
Different distances comparing right side to left or front springs vs rear springs? Your description is a little on the vague side.
CSP is offline
post #5 of 7 Old 10-11-2013, 08:40 AM Thread Starter
napaguy
sorry let me try and clarify..focusing on just the front leaf spring. When measuring from right to left across the width of the frame. I was thinking the hangers would be the same distrance apart for the front and rear. Does that make sense? Im not good with words so please let me know if I can clarify
napaguy is offline
post #6 of 7 Old 10-11-2013, 10:02 AM
WindKnot
1977 CJ7
If you are talking about the shackle (the part that hangs from the frame and attaches to the leaf spring at the bottom) then yes, the shackle at the front is wider apart than the shackle at the rear. The SPRING is the same size all the way down the length, but the BUSHINGS are thicker (fatter?) on the front shackle than on the rear.
Why? Because the frame member widens a bit as it reaches the front. The thicker bushing makes up for it.
Does that answer your question?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 7 Old 10-11-2013, 11:12 AM
CSP
I think the comparison is the distance at the shackle end of the front spring to the distance at the fixed end of the spring.
This distance should be the same, but it has to be measured from center to center. The bushings at the shackle end have a smaller shoulder on them than the fixed end, so the measurement must be the center to center distance at each end of the front spring.
CSP is offline
