CJ7 Front Hub Assembly Swap - JeepForum.com
post #1 of 5 Old 04-22-2012, 05:20 PM Thread Starter
ParsonMac
While in Moab this last week, I decided to take a look at the bolts holding my Superwinch (junk) hubs to the hub/rotor assembly flange as I'd been having trouble keeping them snug. Wouldn't you know, two of them where sheared off leaving the stud in the hub flange. I now only have two bolts (one was sheared off when purchased from PO) holding the hub to the mounting flange. I'd like to replace the '82 five bolt hub/rotor assembly with the 76-81 6 bolt and add Warn Premium hubs. Are bearings, wheel washers etc. cross compatible? What about the spindles? Thanks in advance!
ParsonMac is offline
post #2 of 5 Old 04-22-2012, 05:23 PM
mrgimble
2015 JK Wrangler
76-86 spindles, bearings, nuts etc are all the same. There are 3 different brake setups, but the 6 bolt hubs will fit your rotors so you can use 6 bolt lock outs. Just press the wheel studs out of the 5's and press them in to the 6's
mrgimble is offline
post #3 of 5 Old 04-22-2012, 05:34 PM
85LaredoCJ7
Everything is compatable. Here are my 6 bolt premium conversions on my '85 7. Plus they just look b i t c h i n'
The Dude abides....
85LaredoCJ7 is offline
post #4 of 5 Old 04-22-2012, 05:46 PM Thread Starter
ParsonMac
Sweet! Thanks alot
post #5 of 5 Old 04-30-2012, 11:26 AM Thread Starter
ParsonMac
Update: Went to fastenall for studs to repalce bolts and he presented me with Nord-Lock Bolt securing system. Here's what their website says:
"Nord-Lock bolt securing systems use geometry to safely lock bolted joints in the most critical applications. The key is the difference in angles. Since the cam angle "α" is larger than the thread pitch "β", the pair of washers expand more than the corresponding pitch of the thread. Any attempt from the bolt/nut to rotate loose is blocked by the wedge effect of the cams.
Nord-Lock washers are available in steel, stainless steel and SMO. All washers are ELV and RoHS compliant. In order to facilitate assembly Nord-Lock washers come pre-assembled in pairs (glued)."
I'm gonna try them out on my current setup. I'll keep you posted on how well they do.
assembly , brakes , cj7 , hub , swap
Front Turn Signal Assembly 82KansasCJ Jeep CJ Forum 6 02-28-2014 07:58 AM
Front clip assembly help JackScandia Jeep CJ Forum 1 01-13-2012 06:25 AM
front axle assembly issue Johnnylaw Jeep CJ Forum 5 12-19-2011 04:36 PM
new front disks or disk/hub assembly? twoleos617 Jeep CJ Forum 4 04-28-2009 06:52 PM
YJ front grill assembly fit cj7? Big_E Jeep CJ Forum 9 04-12-2009 02:31 AM
