Cj7 frame ground clearance question - JeepForum.com
post #1 of 2 Old 11-09-2013, 11:27 AM Thread Starter
WindKnot
1977 CJ7
I need some help. I am trying to determine once and for all what the stock FRAME RAIL ground clearance was for my '77 CJ.
In the chart below, all the measurements for the side view of the frame are from a DATUM LINE and not ground level. This makes sense because different sized wheels & tires would affect actual ground clearance. Does anyone know where that datum line is set? Is it for example set at 7 1/2 inches below the center of the axles? (15 inch wheel was stock, 7 1/2 inches would equal the bottom of the rim.)
Does anyone know? Or does anyone know offhand just what the actual measurement of what measurement "A" or "D" equals? Or measurement "C"? (center of the hole for the rear spring mount)
Thanks
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #2 of 2 Old 11-09-2013, 03:37 PM
Spieg8
1984 CJ8
Don't know for sure, but it would make sense to me that the measurements would be based from the center of the axle
Spieg8 is offline
