CJ7 Frame Crack cure? - JeepForum.com
post #1 of 3 Old 10-09-2003, 09:51 AM Thread Starter
Muttley
Muttley's Avatar
I have a 1986 Jeep CJ7 with some problems in the frame: both front end sides are cracked near the spring mount.
I tried to weld then but the crack appear again over the weld.
Does anybody know a "cure" for that or how to make a GOOD reinforcement there?
If you can send me any www where I can take a look in pictures or articles about that I will appreciate!
Thankx
Muttley
From Brazil
Azad "Muttley" Tarikian
Sao Paulo - Brazil
.br
1986 Jeep CJ7 Renegade
Muttley is offline
post #2 of 3 Old 10-09-2003, 10:04 AM
gumby
gumby's Avatar
repair
Ok this time when you weld it take the stress of the weld area first. then grind a groove \ / looks like this on bothsides into the weld area. it should not crack unless the material itself is flawed. when welding this area make sure the slag from welding is gone by chipping with a hammer the area after you done welding. your looking for complete beads an no pitting in the weld if your still in doubt about the weld tack on a scab patch over the welded area
Thankx
Muttley
From Brazil
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline
post #3 of 3 Old 10-09-2003, 10:19 AM Thread Starter
Muttley
Muttley's Avatar
I already tried the "grove" process... but the crack re-opened!
Is that crack appears to a lot of CJ7s frame or its just on mine?
Thankx
Muttley
Sao Paulo - Brazil
.br
Muttley is offline
Is this crack in my frame a big deal? 1BigPig Jeep CJ Forum 10 02-06-2010 07:10 AM
ARRGH! Frame Crack emptypockets Jeep CJ Forum 16 09-09-2009 11:01 PM
A cure for bumpsteer maybe BioTex Jeep CJ Forum 23 03-20-2009 04:34 PM
both of my motor mounts had crack near the frame meatloaf Jeep CJ Forum 2 10-25-2008 11:25 AM
Another frame crack-- when should i worry? RARECJ8 Jeep CJ Forum 7 04-23-2005 09:27 AM
