CJ7 engine will turnover but not start - Page 3 - JeepForum.com
post #31 of 35 Old 06-20-2013, 09:09 PM Thread Starter
jguess1
They looked burnt and black.
jguess1 is offline
post #32 of 35 Old 06-20-2013, 09:27 PM
LumpyGrits
Rich!
LumpyGrits is offline
post #33 of 35 Old 06-21-2013, 12:34 AM
BagusJeep
1981 CJ7
jguess,
Sounds like you are jumping arund a bit there from one symptom to another without being methodical and ruling something out.
Fuel
Ok, you now know the fuel pump works
But you are not getting fuel into the engine.
That only leaves the carb. You are going to have verify this is the problem and take it apart. A common issue is the float bowl and the inlet valve. A piece of dirt can lodge in the inlet or the float be set too low.
Spark
Those platinum plugs may not be good. Ordinary plugs work best, nothing fancy. You need to gap them correctly and check you have a regular bright crisp blue spark. If tey are gapped and you do not it is because your coil is not deenergising properly. Have a look at the voltage at the coil and whether the engine is properly grounded.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #34 of 35 Old 06-21-2013, 10:31 AM Thread Starter
jguess1
Thank you all for your help. I am very new this and have enjoyed working on the jeep. As for the spark plugs they are gapped correctly but did not have a blue spark. I am not sure how to start on either one of the recommendation you had for the carb or volt check. Do you know of a good step by step explanation out there?
jguess1 is offline
post #35 of 35 Old 07-03-2013, 05:32 AM Thread Starter
jguess1
The float bowl was the problem. I have got the engine running again. However, when the engine is cold I have to spray carb cleaner in the carb to start the engine. After it warms up I do not have any problems. Do you all have any recommendation?
jguess1 is offline
