CJ7 engine will turnover but not start - Page 2 - JeepForum.com
post #16 of 35 Old 06-05-2013, 11:32 PM
LumpyGrits
Originally Posted by gurlcj View Post
I'm having starting issues also. Running that lead is the only way I could get it to start! So, your saying it's an ignition switch gone bad? I've changed the coil Also, i get one spark and only one. Its when I let off the key. Still the switch I was leaning toward the pickup coil.
The ing switch is the first place I look. Then the wiring.......
Make sure the wiring connector on the s'colume is not damaged.
LG
LumpyGrits is offline
post #17 of 35 Old 06-06-2013, 05:36 AM
gurlcj
LG
Ok, I'm all over it when I get home
gurlcj is offline
post #18 of 35 Old 06-15-2013, 03:30 PM Thread Starter
jguess1
Ok so I thought my problem was fixed but its not. Turns out I am not get fuel to carb I guess. I just pour a few drops directly into the carb and it started right up. Then it ran fine until I turned it off. What would you all recommend to do first. I just replaced the fuel filter and lines from the electric fuel pump to the carb.
jguess1 is offline
post #19 of 35 Old 06-15-2013, 03:43 PM
LumpyGrits
Does your FP, pump?
Could you have pinched a line?
Hope your ele FP is near the gas tank as ele FP's are 'pushers' and not 'suckers like the OEM mech. FP is.
LG
post #20 of 35 Old 06-15-2013, 09:10 PM Thread Starter
jguess1
When I unplug the fuel line into the fuel filter fuel leaks out. I would guess that means my fuel pump is good??? Or would that always be the case??
jguess1 is offline
post #21 of 35 Old 06-15-2013, 10:14 PM
LumpyGrits
Crank the eng with the line off, and it should SQUIRT, big time.
What about on the carb side of the fuel filter??
LG
post #22 of 35 Old 06-15-2013, 10:26 PM
LeePrather
1978 CJ5
Does your fuel filter have a return line to the tank?
LeePrather is offline
post #23 of 35 Old 06-16-2013, 09:19 AM Thread Starter
jguess1
Yep. The first time I put the new one on they we reversed. I have since switched them.
jguess1 is offline
post #24 of 35 Old 06-16-2013, 09:40 AM
LeePrather
1978 CJ5
When I bought mine in march my return line off the fuel filter was plugged. I, with the honest intention of fixing all the PO screw ups, was gonna fix that and put back in my return line. So I did. My car wouldn't start. Long story short, I had to plug that line back to make it run. I replaced my fuel pump because I wasn't getting fuel to the carb, I replaced my rubber fuel lines on both sides of the vehicle and I replaced my fuel filter. None of those helped until I plugged the return line back.
A) if you are gonna keep that return line make sure that line is on top of the line going to the carb or you cause vapor lock
B) if you are like me and your 600cfm Edelbrock is too thirsty, you might consider plugging up that return line
post #25 of 35 Old 06-20-2013, 09:13 PM Thread Starter
jguess1
So I pulled the fuel line off the carb and put it in a water bottle. Turn the electric fuel pump on and fuel pumps into the bottle. I went back to the spark plugs and checked 4 (this was the first thing I changed out all 6 brand new). The 4 had a light orange small spark, definitely not blue. They were also already black. Could this possible be the problem.
I have not tried to plug the fuel return yet. I am rookie at this and trying to learn as much as possible. So that was going to be my last step.
jguess1 is offline
post #26 of 35 Old 06-20-2013, 09:26 PM
LumpyGrits
YUP--you got a 'weak'/COLD spark.....
What plugs are "U" use'n?
LG
post #27 of 35 Old 06-20-2013, 09:39 PM Thread Starter
jguess1
Autolite Double Platinum Spark Plug
Just replaced them too. Right after it would not start, that was the first thing I did. What should I check/replace next?
jguess1 is offline
post #28 of 35 Old 06-20-2013, 09:42 PM
LumpyGrits
Put the old plugs back in..........
LG
post #29 of 35 Old 06-20-2013, 09:48 PM Thread Starter
jguess1
They were in very bad condition
jguess1 is offline
post #30 of 35 Old 06-20-2013, 09:57 PM
LumpyGrits
Such as.........
