cj7 engine swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > cj7 engine swap
Poison Spyder DeFender Inner Fender KitsCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WDJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 06-29-2014, 09:03 AM   #1
twistedaase
1983 CJ7
cj7 engine swap
I picked up a used engine for my 83 cj7 yesterday i ran the part number and it appears to be an engine out of an 88 jeep. It is a 4.2 6cylinder. There are some differences between my old engine and the one I picked up as far as motor mounts. Does anyone know if this engine will fit in my cj? This is stamped on the used motor MoparJR524270AA
twistedaase is offline   Reply With Quote
Unread 06-29-2014, 09:06 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Yes it will fit. Yj's use different mounts, but your CJ ones will bolt on. You will need to swap or get a new pilot bushing for the crank as the YJ one uses a larger bearing. Other than that, you are good to go.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 06-29-2014, 10:04 AM   #3
twistedaase
1983 CJ7
Okay it looks like the motor mounts fit. Thanks Mike. Do you know what bushing I will need.
Unread 06-29-2014, 10:05 AM   #4
1949er
If they have the same drive belts also - Serp. VS. V-belt the water pump rotation is reversed.
1949er is offline   Reply With Quote
Unread 06-29-2014, 10:11 AM   #5
twistedaase
1983 CJ7
yeah the 88 engine has a serp the 83 I think had multiple belts. The engine came with everything attached. water pump,alternator,clutch, and also a ac compressor which mine did not have ac. I wonder how difficult it would be to set the 83 up with ac
Unread 06-29-2014, 10:56 AM   #6
Mike Romain
A lot of work and parts. But, think of it this way, I believe that AC pump can be converted to an onboard air pump.
Mike
Unread 06-29-2014, 10:58 AM   #7
RenoF250
You can always use the AC for an onboard air pump. I just put a 1994 in mine and it bolted in. You might find the DS engine mount has one larger metric bolt.
RenoF250 is offline   Reply With Quote
Unread 06-29-2014, 10:58 AM   #8
Mike Romain
I used the bushing out of my 258 because I knew it wasn't that old. It was slightly too large so I used a grinder carefully to make it right. You need the bushing to match the tranny.
Edit, a 258 one should just fit, I put a 4.0 in mine.
Mike
Unread 06-29-2014, 11:07 AM   #9
twistedaase
1983 CJ7
i cant find my bushing from my old engine. I guess i am going to have to buy a new one.
Unread 06-29-2014, 11:26 AM   #10
twistedaase
1983 CJ7
interesting thought on the air pump
Unread 06-29-2014, 11:30 AM   #11
bptactical
Details on the AC compressor mod would be great.
bptactical is online now   Reply With Quote
Unread 06-29-2014, 11:40 AM   #12
Mike Romain
If you didn't force it out of the old engine with a puller or you can pack the hole full of grease and use a dowl or bolt the exact size of of the bushing to pound into the grease which will pop the bushing out, it is still in the old crank.
Mike
Unread 06-29-2014, 11:42 AM   #13
Mike Romain
I would do a Google search. I know some types of pumps work and some don't, but you have the bracket there anyway so getting one from the wrecker cheap or as a swap isn't out of the question.
Mike
Unread 06-29-2014, 01:38 PM   #14
RenoF250
I believe they all work it is just a question of how long. The crank pumps like the York have am oil crankcase and the swash plate style that he likely has relies on oil in the Freon for lubrication. I think you could add an oiler to the intake and get decent life out of the swash plate style but I have no experience with it.
Unread 06-29-2014, 01:47 PM   #15
RenoF250
Here is a good article on it. I will probably put the Cherokee compressor I have on. Sounds like they run for quite awhile without much oil. Since I only need it for airing tires it will not have to run much.
http://www.nwjeepn.com/onboardair.htm
