Cj7 electrical grounding - JeepForum.com
post #1 of 4 Old 08-18-2013, 09:59 AM Thread Starter
kuhndogs
1983 CJ7
All right. I have tested the gauges and replaced those that were not functional. I am seeking advise or guidance on the BEST method to GROUND the gauges so they work. Most of the schematics or suggestions refer to testing with the OHM meter or show the post location/color of the + connector... but nothing about HOW to properly ground -or- where to mount the ground wires for the gauges.
kuhndogs is offline
post #2 of 4 Old 08-18-2013, 10:22 AM
LumpyGrits
OEM ground was the clamp behind the gauges, against the back of the dash.
LG
LumpyGrits is offline
post #3 of 4 Old 08-18-2013, 06:24 PM
John Strenk
John Strenk's Avatar
1976 CJ5
For oil and volts yes
For fuel and temp. It's tricky. First the gauge has a spring clip that grounds it to the speedometer housing and the housing should have nuts with star washers that attach it to the dash. The dash to the tub and a ground wire from tub to ... someplace. I never had a stock jeep so I can't say how the tub was originally grounded.
John Strenk is offline
post #4 of 4 Old 08-18-2013, 07:28 PM
scottymac62
1979 CJ7
I have a central grounding location mounted on the inside of the fenderwell close to the battery. I ran a independent ground for everything that depends on a good ground to it. Ignition, dash gauges, Fuel sender, engine block, etc.
It makes all the difference in the world when your CJ can flow its electrons like it is suppose to.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
