cj7 electrical - JeepForum.com
post #1 of 7 Old 11-12-2013, 06:49 PM Thread Starter
harleydan
cj7 electrical
When I start the jeep and then turn on the headlights the jeep shuts off. If I keep my foot on the gas it will stay running.
harleydan is offline
post #2 of 7 Old 11-12-2013, 07:07 PM
John Strenk
John Strenk's Avatar
1976 CJ5
What does your volt meter say when you turn the headlights on?
If the voltage drops too low, the engine will stop.
If there is a poor connecton to the electrical system then you will not have enough power to run the jeep.
I assume that the battery is good and so are the cables because you can still start the jeep.
Check the battery voltage with the engine running. it should be around 14 volta.
John Strenk is online now
post #3 of 7 Old 11-12-2013, 08:23 PM
LumpyGrits
What's your engine rpm when it dies?
Have your alternator check'd for amp output.
How old is your battery?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 7 Old 11-13-2013, 10:24 AM
AcidLamp
Check your grounds. Then check them again.
AcidLamp is offline
post #5 of 7 Old 11-21-2013, 11:28 AM Thread Starter
harleydan
All thanks for the info the battery is new when the jeep is running the alternator reads 14 volts out. I will have to check the grounds better. the jeep sat for about 6 months.
post #6 of 7 Old 11-21-2013, 11:45 AM
LumpyGrits
New batts go bad.
Get a 'battery maintainer' to save your battery.
http://www.walmart.com/ip/Schumacher...arger/13005742
LG
post #7 of 7 Old 11-24-2013, 01:39 PM Thread Starter
harleydan
Had time to check out Saturday it looks like it was the ground wire to the control box some of the wire inside were fraded.
Thanks. to all for your help.
