CJ7 Electric Fuel Pump Mounts and Locations - JeepForum.com
post #1 of 17 Old 09-05-2013, 10:03 AM Thread Starter
Frenimy
1981 CJ7
I just got a used Howell TBI. I am trying to source a good fuel pump and I need to know where a good mounting spot is and where I can get mounts for it and how they attach. I have read several threads that say they use hose clamp mounts but I would like to see some pics of different mounting solutions and know where you guys got your mounts. Also are you using a bracket mount for the filter or just letting it hang there?
1981 CJ7 I6 258, NP435, Dana 300 Twin Sticks, AMC 20 & Dana 30 with Lockers, On board air, 33" X 12.50" tires
Frenimy is offline
post #2 of 17 Old 09-06-2013, 08:26 AM Thread Starter
Frenimy
1981 CJ7
Anyone have any solutions?
Frenimy is offline
post #3 of 17 Old 09-06-2013, 08:33 AM
CJ7ROB
Here's mine...mounts are from plumbing supply store. Wrapped the pump and filter in rubber liner. Rock solid..
CJ7ROB is offline
post #4 of 17 Old 09-06-2013, 10:37 AM
jeepnjeff1002
1982 CJ8
I put mine on the frame rail:
1982 CJ8 currently being rebuilt. AMC 360 V8, TF727, dana 60, 14 bolt, atlas II, build: http://www.jeepforum.com/forum/f8/jeffs-offroad-cj8-build-1320142/
jeepnjeff1002 is offline
post #5 of 17 Old 09-06-2013, 11:01 AM Thread Starter
Frenimy
1981 CJ7
Thanks for the responses I like both ideas I will check out some of the plumbing parts for mounts ideas. CJ7ROB what type of rubber did you use and what was it intended for so I can try to find some?
Frenimy is offline
post #6 of 17 Old 09-06-2013, 11:03 AM
AFRd_CJ5
1976 CJ5
My fuel system is a little different now, but the pump is still in the same location. Mounted on a bracket to the frame rail.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #7 of 17 Old 09-06-2013, 11:25 AM
WindKnot
1977 CJ7
AFRd_CJ5, aren't you afraid of it snagging something on the trail? Or is there a guard or plate for it we don't see?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #8 of 17 Old 09-06-2013, 11:29 AM
Gigemags05
1980 CJ7
I mounted mine on the rear crossmember. As close to the tank as I could get it.
I am running an E2000 fuel pump. For mounts, I used steel strapping that I wrapped around the pump and screwed into the crossmember.
Gigemags05 is offline
post #9 of 17 Old 09-06-2013, 11:32 AM
CJ7ROB
I have a big koi pond and I had extra rubber from the pond liner. Its nice and thick, supposed to last 20 yrs outdoors.
CJ7ROB is offline
post #10 of 17 Old 09-06-2013, 12:05 PM
AFRd_CJ5
1976 CJ5
My Jeep sees sand dune use, sand drags, asphalt drags, and street driving. I never do any rock/trail use with it, so definitely not an issue for me
'76 CJ5
AFRd_CJ5 is offline
post #11 of 17 Old 09-06-2013, 03:04 PM
dg6772
I mounted my pump in the tank.I'm running a 350tbi system and put everything in the factory positions as if it were in a Chevy truck.
Dave in Muskegon
dg6772 is offline
post #12 of 17 Old 09-10-2013, 08:45 AM Thread Starter
Frenimy
1981 CJ7
I have decided to use an E2000 or E2182 pump. I checked ebay and it seems there are several people that make a compatable pump for 1/3 to 1/2 the cost of AZone($80). Does anyone jknow anything about these cheaper pumps or should I avoid them like the Plague? I don't mind paying the extra money for quality but don't want to if I don't have to.
Frenimy is offline
post #13 of 17 Old 09-10-2013, 09:33 AM
Gigemags05
1980 CJ7
I went with an airtex pump. I wouldn't trust the EBay cheapos for the fuel pump.
I think I got mine for $65 on amazon, which was a little cheaper than autozone
post #14 of 17 Old 09-10-2013, 09:49 AM
Blakescj7
Make sure you get a pump that can supply the right amount of psi for your system also.
Blakescj7 is offline
post #15 of 17 Old 03-05-2014, 03:38 AM
kjhibbs
1981 CJ8
Dave in Muskegon
Dave, did you have to modify your CJ tank for the 350 pump and sender to fit?
1981 Scrambler; Vortec 4.3 / 4l60e swap; 35s; getting close!
kjhibbs is offline
