CJ7 Choke - JeepForum.com
post #1 of 16 Old 01-05-2012, 08:07 AM Thread Starter
scstrick79
CJ7 Choke
Got a question concerning an 85 CJ7 choke. I think that it is an electric choke as I dont have a manual control...
When it is cold, I need to pop the hood and and open the flap to the carb manually to crank the jeep. I have to this sometimes once the engine is warm to start as well! How can I diagnose this as its rather irritating to have to pop the hood to crank!?!?
scstrick79 is offline
post #2 of 16 Old 01-05-2012, 08:33 AM
lucdog
1980 CJ5
Electric choke.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 16 Old 01-05-2012, 08:45 AM
Outnumbered
Choke butterfly should be closed to start a cold engine and open to start or run a warm engine. If it is closed when it shouldn't be, it will cause a rich condition making it hard to run or start the engine.
1985 CJ7, 258, TF999, D300, D30, AMC20, 4.5" lift, 33" BFG's
Outnumbered is offline
post #4 of 16 Old 01-05-2012, 09:19 AM
MoC
The picture below (not mine) is how the choke should be wired for your 258. If the po stripped the wiring out you can just run a switched hot to the choke and will be fine. If you do have a wire going to the choke the first thing I would check is to see if it has power to it.
MoC is offline
post #5 of 16 Old 01-05-2012, 09:39 AM Thread Starter
scstrick79
ok... apparently it is not an electric choke as i dont have anything that looks like that. What i have looks almost like a thermostat with a "piston" running in the middle. this piston is connected to the carb and controls the flap. Even with the engine cold, the flap is all the way closed not allowing any air. Could the "thermostat" be my problem?
post #6 of 16 Old 01-05-2012, 09:59 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Sounds Like you are missing the black cap in the picture above
Is this what you see:
Yours will not have that pipe on it.
This is what is probably missing
John Strenk is offline
post #7 of 16 Old 01-05-2012, 10:05 AM Thread Starter
scstrick79
yep, thats what it looks like... now, what do i do from there?
post #8 of 16 Old 01-05-2012, 10:11 AM
John Strenk
1976 CJ5
Need to get a cap and ring. The cap is the easy part. Everyone sells them.
Getting the ring that holds it on and makes the ground connection is the hard part to find.
Maybe someone has one laying around someplace
They seem to be pretty much a universal size.I used ones off a Motorcraft and made it work.
post #9 of 16 Old 01-05-2012, 11:01 AM
Outnumbered
I thought you could buy a replacement electric choke but I've never looked for one. Another option is to install a manual choke. Just a push/pull knob with a cable routed into the dash area. I like manual chokes, almost too simple to fail.
post #10 of 16 Old 01-05-2012, 11:12 AM
Outnumbered
post #11 of 16 Old 01-05-2012, 12:31 PM
Outnumbered
Looks like this ring may work also...
http://www.ebay.com/itm/Ford-Motorcr...34859771095104
post #12 of 16 Old 01-05-2012, 12:47 PM Thread Starter
scstrick79
Actually, i have the ring and cap and it is plugged in... it looks correct... i was just looking at it wrong. Anyway, any ideas where I can go from here?
post #13 of 16 Old 01-05-2012, 12:58 PM
Outnumbered
post #14 of 16 Old 01-05-2012, 01:00 PM
Outnumbered
I would try checking the wiring and compare to the diagram posted above.
Here is some testing info I found in a search...
http://www.jeepforum.com/forum/f8/el...-test-1054106/
post #15 of 16 Old 01-05-2012, 01:01 PM Thread Starter
scstrick79
Yeah, Outnumbered... felt pretty boneheaded about that one...
choke , cj7
Choke season again! Carter bbd choke JeepHammer Jeep CJ Forum 42 10-20-2015 04:49 PM
electric choke vs. manual choke... hex Jeep CJ Forum 12 08-18-2013 09:29 PM
Automatic choke MYV8ROX Jeep CJ Forum 0 03-23-2010 09:00 PM
73 cj5 hot air choke dsfordguy Jeep CJ Forum 5 03-17-2009 03:39 PM
manual choke GeauxJeep Jeep CJ Forum 3 02-12-2008 11:53 AM
