cj7 to chevy - JeepForum.com
post #1 of 16 Old 08-08-2012, 11:34 PM Thread Starter
jnowen18
1979 CJ7
cj7 to chevy
I am putting a complete chevy drivetrain under my 79 cj7 has anyone ever done this please post pictures if so. I am using a 85 chevy 350,sm465 with 208 t-case and chevy 3/4 ton axles. I mainly need the drive line angle for the rear and what i can make work for a tranny mount/crossmember
jnowen18 is offline
post #2 of 16 Old 08-08-2012, 11:50 PM
sandstrom
1982 CJ7
Sounds like that will be a strong rig once ya get it going good luck to ya!!!
mitch95
sandstrom is offline
post #3 of 16 Old 08-09-2012, 08:01 AM
CSP
That's a long drivetrain for a CJ. Personally I'd adapt a Dana 300 to the SM465 and lose the long NP208.
CSP is offline
post #4 of 16 Old 08-09-2012, 08:07 AM
bigredisb
1979 CJ7
I am no 208 expert but I wouldnt want the slip yoke on it. With the drive line angles you will have it will more than likely bind and get sticky. Even on my dads K5 blazer it would stick and shudder when compressing the rear axle.
You can convert your 208 to a fixed yoke (unless it is already) but I would put the money towards the 300.
The 300 would be well worth the investment.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #5 of 16 Old 08-09-2012, 08:55 AM
18chad
1983 CJ7
I have a shortened silverado frame under my cj, I'm currently putting a 350 in it but my concept is a little different from yours..
18chad is offline
post #6 of 16 Old 08-09-2012, 08:56 AM
CSP
That's a good point too. I forgot about the 208 having a slip yoke.
CSP is offline
post #7 of 16 Old 08-09-2012, 11:27 AM Thread Starter
jnowen18
1979 CJ7
i think i have figured out my driveline angle with the slip yoke i will try to post pictures after i get some other mods done
jnowen18 is offline
post #8 of 16 Old 08-12-2012, 02:37 PM Thread Starter
jnowen18
1979 CJ7
what do yall think its not permanent but should work for a few runs through the mud
jnowen18 is offline
post #9 of 16 Old 08-12-2012, 03:22 PM
82JeepCJ7
1982 CJ7
Unless your running a CV drive shaft, that is going to vibrate and spit U-joints like crazy. Pretty short as well.
What is the steering setup in the front? IIRC the drivers side knuckle had the boomerang arm on it and a short link to the steering gear box. Hopefully your doing cross over steering.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #10 of 16 Old 08-12-2012, 04:45 PM
papa355
1977 CJ7
How about stretching it while ur at it? Wouldn't be a big deal, as far down as you are now. (if you have the resources, time and skills) Just asking. That would help the angles out alot. Is this just a mud runner, trail rig? Are you using the stock hangers (like I see in the pic) or outboarding? Just some other options for you to ponder
1977 CJ7, 360 AMC with HEI, TH400 quadratrac, dana30, AMC20, SOA, 35" M/T MTZ
papa355 is offline
post #11 of 16 Old 08-12-2012, 05:57 PM Thread Starter
jnowen18
1979 CJ7
its gonna be a mud buggy/trail rig and i plan on putting a different t-case in this winter i just wanna get it done and running before mudfest in my town prolly 4 runs through the pit. i am running fully hydraulic steering on the front everything from PSC, and stretched the front with shackle reverse and with the rear i am running it stock.
423464_405271376196486_1787787965_n.jpg   574629_405272259529731_602224566_n.jpg
jnowen18 is offline
post #12 of 16 Old 08-21-2012, 09:22 PM Thread Starter
jnowen18
1979 CJ7
Took everyone's advice I got a built turbo 350 and 205 transfer case
jnowen18 is offline
post #13 of 16 Old 08-22-2012, 07:31 PM
papa355
1977 CJ7
I'd still stretch the rear back some. When I go to full width's I'm going to move it back some.
papa355 is offline
post #14 of 16 Old 08-22-2012, 08:27 PM
Niedhogg
1979 CJ7
I have the exact same driveline to put into my CJ, but I plan on stretching and linking the rears... it looks a little short and steep to me as well...
Niedhogg is offline
post #15 of 16 Old 08-24-2012, 09:09 PM Thread Starter
jnowen18
1979 CJ7
With the 350 and 205 it is a lot better of an angle and a LOT shorter than that 465 /208
jnowen18 is offline
AMC 360 or Chevy 350 CowboyT2 Jeep CJ Forum 20 01-04-2012 08:01 AM
CJ7 Chevy V8 to Chevy LS V8 conversion ScottyRock155 Jeep CJ Forum 0 04-03-2011 12:48 AM
Who has a Chevy 350 in your CJ? SupaJosh Jeep CJ Forum 14 04-12-2010 04:34 PM
chevy 350 help FF151DJG Jeep CJ Forum 4 04-16-2008 06:06 AM
Chevy 350 in a CJ7? Vspec Jeep CJ Forum 3 10-24-2003 06:59 AM
