cj7 caster angle - what should it be? - Page 3 - JeepForum.com
post #31 of 41 Old 08-24-2010, 08:48 PM
gelmhorst
1976 CJ5
They are already installed so I guess I didn't take a really close look at it. You are probably right. The jeep is only going to be driven ocasionally on sunny days, so I am not too concerned about durability of the shims. I have not installed degree shims before and would appreciate any direction? Do I purchase longer bolts and bolt the shim to the leaf springs? Would welding the shims to the perches be stronger and more secure?
gelmhorst is offline
post #32 of 41 Old 08-25-2010, 09:07 AM
Chewtoy
1976 CJ5
That would lead to my next question, please forgive if it seems a bit ignorant. Instead of turning the knuckle, would it not be easier to reset the spring perch back the required 4-5*?
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #33 of 41 Old 08-25-2010, 09:16 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
I believe you meant rotate the perch forward on the tube, but the question was understood.
While easier than rotating the knuckle yoke, that will also rotate your pinion down by the same amount.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #34 of 41 Old 06-28-2013, 08:43 AM
jraynal
1981 CJ7
If the caster is moved negatively (axle rolled forward) due to a lift, isn't it conceivable that the pinion angle will be moved from its original position? And, the proper way to fix this is to modify the spring perchs of rotating the “Cs”?
jraynal is offline
post #35 of 41 Old 06-28-2013, 11:04 AM
Renegade82
1982 CJ7
Yes, but that's not a do-it-yourself job that many folks can do. That requires the correct tools and skills and most likely a jig for accurate placement of the angles involved.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #36 of 41 Old 01-26-2015, 07:30 PM
2001WJv8
2015 WK
I took my cj7 in for an alignment thinking the toe may have been off, came back with the following:
Left Front: Right Front:
camber: -.04 -.04
caster: 4.3 3.9
toe: .05 .04
so my question is this, the caster is about 2* off, but i've had it up to 80mph on the interstate and it tracks straight and effortless ... as such, I'm tempted to leave well enough alone being only 2* off and not having problems (?) any opinions?
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #37 of 41 Old 01-26-2015, 10:10 PM
CSP
If it aint broke, don't fix it.
CSP is offline
post #38 of 41 Old 01-27-2015, 12:18 AM
only in a jeep cj
camber: -.04 -.04
caster: 4.3 3.9
toe: .05 .04
Do you have lift shackles? The stock ones are 3" bolt to bolt
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #39 of 41 Old 01-27-2015, 06:36 AM
2001WJv8
2015 WK
i''ll measure them, the PO put the 2.5" skyjacker lift on (sorry thought I had that in my sig.)
as CSP posted I'll probably leave it alone ... as much as I prefer to have things correct, since it isn't giving me problems and won't ruin my tires no reason to change it up right now
2001WJv8 is offline
post #40 of 41 Old 01-27-2015, 12:05 PM
Renegade82
1982 CJ7
camber: -.04 -.04
caster: 4.3 3.9
toe: .05 .04
Castor is not an exact number it must be. It should fall within a range.The fsm for later Jeeps put's the castor at 5-7 deg. pos. That doesn't mean that 4.75 deg. is going to give you poor steering, only that it's heading that way. So if it works where it's at... leave it. As CSP said, "if it ain't broke.....
post #41 of 41 Old 01-27-2015, 07:30 PM
2001WJv8
2015 WK
thanks for the confirmation, I was more worried toe was off and would rip up the tires since I had just gotten the jeep and noticed some weird lug wear on the fronts ... wasn't sure when I got the results back if I should address the caster or not so I'm just going to leave it alone until a problem develops
2001WJv8 is offline
camber , caster , steering alignment , steering caster , toe in , toe out
How do measure caster angle? scarlett Jeep CJ Forum 3 05-23-2009 05:40 AM
Another Caster angle questions Dad03 Jeep CJ Forum 1 02-23-2009 06:43 PM
caster angle ? drunkenrich Jeep CJ Forum 2 02-11-2008 07:13 AM
Checking caster angle... 79cj7reny Jeep CJ Forum 5 11-24-2007 07:14 PM
Caster angle question jode Jeep CJ Forum 8 01-23-2007 04:41 PM
