CJ7 Carter BBD Vacuum Line Help - Page 9 - JeepForum.com
post #121 of 201 Old 07-05-2013, 02:45 PM
LumpyGrits
OK-my CRS was in full bloom Also, my son has my FSM, so I could not look it up.
Still need to see what the level is run'n, to best set the float.
LG
LumpyGrits is offline
post #122 of 201 Old 07-05-2013, 02:49 PM Thread Starter
KnoxButler
1981 CJ7
Ok so let me get this right... im going to take everything off the top of the bowl section of the carb. Take out the spring and check valve... then i plug the hole where the check valve went??
KnoxButler is offline
post #123 of 201 Old 07-05-2013, 02:52 PM
LumpyGrits
CORRECTION!!!!
Where the piston next to the acc. pump goes is what needs to be plugged.....
Be freak'n carefull on start up, as you have a cup of 'open' gas.
FWIW: an old AMC 'wrench' taught me this trick.
LG
post #124 of 201 Old 07-05-2013, 02:54 PM Thread Starter
KnoxButler
1981 CJ7
How do I be careful? haha?
post #125 of 201 Old 07-05-2013, 02:58 PM
LumpyGrits
Never buy a Jeep to begin with..........
LG
post #126 of 201 Old 07-05-2013, 02:59 PM Thread Starter
KnoxButler
1981 CJ7
hahah Good point, Ill grab a small clean rag and a big towl to put out flams.... or would it suck up the gas and turn into a tortch?? haha brb...
post #127 of 201 Old 07-05-2013, 03:02 PM
LumpyGrits
Marshmallows work well...........
LG
post #128 of 201 Old 07-05-2013, 03:11 PM
fourbtgait
1930 MK Patriot
As a side note, 86 and LG, what idle rpm do you prefer for the bbd?
650, 750?
Russell
fourbtgait is offline
post #129 of 201 Old 07-05-2013, 03:14 PM Thread Starter
KnoxButler
1981 CJ7
If this goes wrong... its going to be really hard to enplane at the ER burn unit...
post #130 of 201 Old 07-05-2013, 03:16 PM Thread Starter
KnoxButler
1981 CJ7
Hold that though, have to wait for a lightning storm to pass. Although that would be one hell of a story to tell my kids... Back when i was a boy...
post #131 of 201 Old 07-05-2013, 03:19 PM
LumpyGrits
650, 750?
Russell
750-800 because when you 'load' the ele system with lights etc. it will drop some in rpms. You want to keep the battery charged at the stop light.
LG
post #132 of 201 Old 07-05-2013, 03:20 PM
LumpyGrits
Chic's dig scars...........
LG
post #133 of 201 Old 07-05-2013, 03:22 PM Thread Starter
KnoxButler
1981 CJ7
Hahaha
post #134 of 201 Old 07-05-2013, 03:32 PM
fourbtgait
1930 MK Patriot
Thanks, mine was at 650, didn't like how it sounded, bumped it up today to 750.
post #135 of 201 Old 07-05-2013, 03:38 PM
dget42
Pull it out of the carport and don't burn the house down....
dget42 is offline
carter carb , cj7 , egr , emissions , vacuum
