CJ7 Carter BBD Vacuum Line Help - Page 8 - JeepForum.com
post #106 of 201 Old 07-05-2013, 09:51 AM Thread Starter
KnoxButler
1981 CJ7
DMV was packed, drove around for a while, experienced a loss of power, hesitation maybe, happens I start to accelerate from a stop. Engine flutters than almost dies then picks up again jerking me forward then back. Happens a little if i shift too soon. Any ideas?
KnoxButler is offline
post #107 of 201 Old 07-05-2013, 11:20 AM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
Go back to the last thing you adjusted(messed with). Make sure you have no loose wires, bolts, hoses, distributor hold down bolt. More often than not, tightening down a bolt, loose hose, or electrical connection is the culprit. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #108 of 201 Old 07-05-2013, 11:32 AM Thread Starter
KnoxButler
1981 CJ7
Float? I adjusted it, could that be the problem? Ill check all my vacuum lines, i fiddled with those too.
post #109 of 201 Old 07-05-2013, 11:52 AM
Jon In Tucson
1983 CJ5
Yup, a maladjusted float could make problems, as well as a vacuum leak, or even timing. Just be methodical, and retrace your steps, You'll find it. God bless.
Jon In Tucson
panic." - Mike
post #110 of 201 Old 07-05-2013, 01:29 PM Thread Starter
KnoxButler
1981 CJ7
Ok so here is what I think happened, I went in this morning and fiddled with the floats, took it for a test drive and noticed the symptoms and mistook them for timing issues. At that point I had both a float and timing problem. Retraced my steps as you suggested, took the carb off the Jeep reset all the setting (for good measure, they turned out to be a little off anyway) and reset the timing. Haven't taken it for a test run but it idles smoother so that's a good sign.
post #111 of 201 Old 07-05-2013, 01:46 PM
LumpyGrits
You can leave the carb on the eng to do this step.
Remove the top section of the carb. that is held on buy the 6 screws.
BE CAREFUL! Don't lose the acc. pump spring, or the 2 'e' clips.
Now you can start the engine and see where the float level is.
See the two cut-outs at the top of the acc. pump shaft? You want the fuel level to the middle or just a bit more on those cut-outs.
You will need to plug the vac. line to have your eng run 'rite'.
Did you ever order the FSM that you REALLY need to have?
LG
LumpyGrits is offline
post #112 of 201 Old 07-05-2013, 01:56 PM
86cj74.2L
86cj74.2L's Avatar
When you thread the fuel fitting into the carb and then you bend the tab to set float height......do not let the fuel fitting turn when your tightening the fuel line to it. That will drive the fitting deeper into the fuel bowl and lower your float height more than you think.
86cj74.2L is offline
post #113 of 201 Old 07-05-2013, 01:58 PM Thread Starter
KnoxButler
1981 CJ7
Ya iv got a Haynes, I took it for a quick spin and the hesitation is way worse! LG i set the floats to 1/8 below the top of the bowl housing... Ill do what you say and see where they sit. Do i take the spring and check valve out too?
post #114 of 201 Old 07-05-2013, 01:59 PM Thread Starter
KnoxButler
1981 CJ7
Also is it possible that a mixture that is to lean could cause this?
post #115 of 201 Old 07-05-2013, 02:09 PM
LumpyGrits
1/8 from the top is flood'n the engine.
Does the Haynes have a how to section for the carb?
Get a copy of the real FSM from AMC, MR-252 !!!!!!!!!!!!!!!!!!!!!
Go to NAPA, and buy a rebuild kit. It will have ALL the specs you need.
YES, you'll need to plug the bottom because it will be a vac. leak.
LG
post #116 of 201 Old 07-05-2013, 02:15 PM
86cj74.2L
86cj74.2L's Avatar
I believe 1/2 from the top of fuel bowl.
post #117 of 201 Old 07-05-2013, 02:23 PM
fourbtgait
1930 MK Patriot
Maybe this 1982 TSM will help?
It's online.
http://oljeep.com/edge_82_tsm.html
Russell
fourbtgait is offline
post #118 of 201 Old 07-05-2013, 02:27 PM Thread Starter
KnoxButler
1981 CJ7
Sorry I ment 1/4 from the top and I have rebuilt the carb already with a kit.
post #119 of 201 Old 07-05-2013, 02:36 PM
LumpyGrits
If it's a NAPA kit. It will have very good 'how-to's' with the rebuild instructions.
Do you still have those instructions?
1/4" will still flood the engine....Set the float as the instruction's say....
LG
post #120 of 201 Old 07-05-2013, 02:42 PM Thread Starter
KnoxButler
1981 CJ7
Instructions say 1/4, so does repair manual. Thats (.25 in). im measuring from the top of the float to parallel with the top of the float housing...
carter carb , cj7 , egr , emissions , vacuum
