CJ7 Carter BBD Vacuum Line Help - Page 7 - JeepForum.com
post #91 of 201 Old 07-04-2013, 06:54 PM Thread Starter
KnoxButler
1981 CJ7
Ya I haven't had anything like that.
Your Diesel thing reminded me (the wooshing) when I'm driving my Jeep sometimes I notice a sucking sound from somewhere in the engine bay, I assume its coming from in the carb as I first noticed it after I rebuilt mine. It seems to happen more while accelerating I think, the noise is drowned out by other noises so I don't always hear it.
At some time I saw another thread with a post about this but I've had no luck trying to find it again. In the the post/thread someone described it really well as the noise coming from the end of a shop vac, not the noise of the electric motor just that sound of the air being pulled into the hose. I haven't payed much attention to it but I wonder if any of you have had this or heard of someone having this and could offer some advice, or tell me weather I should concern myself with it and finding the source.
PS: I don't think its a vacuum leak, I just don't think a vacuum leak could be loud enough for me to hear it over the engine, wind, etc.
KnoxButler is offline
post #92 of 201 Old 07-04-2013, 07:47 PM
86cj74.2L
86cj74.2L's Avatar
If it still doesn't pass your cat could be dead.
Do you have air injection? That also aids in helping the CAT burn off the unburned fuel.
86cj74.2L is offline
post #93 of 201 Old 07-04-2013, 08:04 PM Thread Starter
KnoxButler
1981 CJ7
Brand new cat (cheapo Autozone one) not air injected, if that means that the cat has a hose that goes to it to help it burn hotter.
Any ideas on the sucking noise?
post #94 of 201 Old 07-04-2013, 08:04 PM Thread Starter
KnoxButler
1981 CJ7
Keep those suggestions coming on the emissions ill run through ideas on anything to help me pass.
post #95 of 201 Old 07-04-2013, 08:08 PM
86cj74.2L
86cj74.2L's Avatar
Someone correct me if I'm wrong but even without the stepper BBD should he have a air pump and such?
post #96 of 201 Old 07-04-2013, 08:46 PM Thread Starter
KnoxButler
1981 CJ7
Its possible, Where would the piping from the cat connect too?
post #97 of 201 Old 07-04-2013, 08:53 PM
LumpyGrits
Not sure about non BBD and a'pump.
LG
LumpyGrits is offline
post #98 of 201 Old 07-04-2013, 09:45 PM
86cj74.2L
86cj74.2L's Avatar
It would be a belt driven pump going to a hole in the exhaust manifold or down pipe.
post #99 of 201 Old 07-04-2013, 10:27 PM Thread Starter
KnoxButler
1981 CJ7
Ya there is an air pump and it appears like its pumping air into the exhaust manifold.
Iv got a new development. I took the Jeep out for one last test drive before I put it up for the night, when I got back and everything was nice and hot I let it sit in my car port while I listened for anything out of the ordinary. I noticed some "puffing" coming from the exhaust, its wasn't backfiring, and there wasn't any smoke or noticeable fumes coming out of the exhaust.
Any ideas what might be causing this? Could switching to ported vacuum possibly help?
post #100 of 201 Old 07-04-2013, 11:21 PM Thread Starter
KnoxButler
1981 CJ7
Happy 4th!
post #101 of 201 Old 07-05-2013, 09:00 AM Thread Starter
KnoxButler
1981 CJ7
Hey guys I took out the timing light again to check the timing with VA plugged. Spot on still, I then reconnected the VA and the timing was higher but as i increased the rpm the timing kept getting higher, my understanding was that it was supposed to drop? Am i wrong and that is what its supposed to do?
post #102 of 201 Old 07-05-2013, 09:08 AM
fourbtgait
1930 MK Patriot
Timing increases with engine rpm.
You only need to set it at idle like you have, then ignore it.
fourbtgait is offline
post #103 of 201 Old 07-05-2013, 09:12 AM Thread Starter
KnoxButler
1981 CJ7
Ok cool thank you Four! Anyone know about the puffing I mentioned earlier?
post #104 of 201 Old 07-05-2013, 09:28 AM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
Knox,
Probably a little engine wear. Valves not completely opening or closing during the compression or exhaust cycle. You can still pass emissions. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #105 of 201 Old 07-05-2013, 09:33 AM Thread Starter
KnoxButler
1981 CJ7
Alright Ill give it a try and report back, thanks Jon!
carter carb , cj7 , egr , emissions , vacuum
