CJ7 Carter BBD Vacuum Line Help - Page 2 - JeepForum.com
post #16 of 201 Old 07-01-2013, 08:45 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by KnoxButler View Post
Sorry I'm confused, on my carb. there is a piece of metal like an inverted u that holds that little pin that the floats pivot on in place.
-Knox
Sorry, not enough cafeen..
It's probably used to keep the gas from sloshing around a lot. and leep it around the floats when at an angle. If all you ever do is drive flat roads you might not miss it.
John Strenk is offline
post #17 of 201 Old 07-01-2013, 09:05 AM Thread Starter
KnoxButler
1981 CJ7
I probably wont be able to keep it on flat roads I cant imagine that the baffle would be able to do a whole lot but none the less, if its within reason I would like to try and get one. Any ideas where I could get one? I cant imagine that its a part Autozone would have, or even be able to order it.
On another note is there any reason that it wouldn't be in there besides a PO forgetting to put it back in during a rebuild? Even then I would think it would be a hard piece to forget, even if the rebuild was finished the piece isnt small or something he must have noticed it was left over. Just doesn't make sense to me unless he was just extremely lazy.
-Knox
KnoxButler is offline
post #18 of 201 Old 07-01-2013, 09:35 AM
John Strenk
1976 CJ5
Everyone I opened up had one in it.
As you say, hard to overlook. But maybe couldn't figure out were it went...\
However, I just went through 3 sites that sell BBD Parts and it lasn't listed in any of them....
https://buy.walkerproducts.com/carbu...omponents.html
http://www.carburetion.com/Carter2.htm
http://www.carburetor-parts.com/Cart...c_151-2-0.html
Mybe you can call one of them and see if they can find it for you.
post #19 of 201 Old 07-01-2013, 11:43 AM Thread Starter
KnoxButler
1981 CJ7
Ya I figured it would be a hard part to find, I did some searching and found this http://www.jeepforum.com/forum/f8/mi...r-bbd-1258346/
Im confused as to why there would not be a baffle in these carbs...
post #20 of 201 Old 07-02-2013, 04:45 AM
John Strenk
1976 CJ5
Yeah, i had 6 BBD's at home and all had baffles.
want me to look for one?
post #21 of 201 Old 07-02-2013, 12:04 PM Thread Starter
KnoxButler
1981 CJ7
If you want to, I would appreciate knowing where to pick one up at. However at the moment im still working through my vacuum lines.
-Knox
post #22 of 201 Old 07-02-2013, 01:39 PM
86cj74.2L
86cj74.2L's Avatar
-Knox
There are only used parts available that I'm aware of. However saying that the company that is now producing the clone BBD (it has the bright white bowl vent instead of off yellow) may have parts available also. I wanted to look into this and never did........
86cj74.2L is offline
post #23 of 201 Old 07-02-2013, 02:44 PM Thread Starter
KnoxButler
1981 CJ7
Hey does anyone know about using Teflon tape with high temps on engines? I was thinking about using it to help seal the threads on my needle and seat, also when I get my CTO valve i was wondering if I should some Teflon on that when i screw it into the intake manifold. But I'm concerned that it will melt or something?
-Knox
post #24 of 201 Old 07-02-2013, 02:49 PM
LumpyGrits
NO TAPE!
Copper anti-seize from NAPA.
Use NUT'N on the carb! You should have a gasket for the needle and seat.
LG
LumpyGrits is offline
post #25 of 201 Old 07-02-2013, 04:13 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by LumpyGrits
NO TAPE!
LG
That is not a thread sealer.
Most things you get will already have thread sealer painted on when you get it. Just spray brake clean on the female threads.
post #26 of 201 Old 07-02-2013, 04:18 PM Thread Starter
KnoxButler
1981 CJ7
Ok awesome got it!
-Knox
post #27 of 201 Old 07-02-2013, 04:24 PM
LumpyGrits
It does work as a thread sealer(to a small point)and makes sure you can take'em apart, down the road.
A/size also maintains electrical contact that t'tape does NOT. Plummers 'putty' also causes ele. contact issues.
LG
post #28 of 201 Old 07-02-2013, 04:42 PM Thread Starter
KnoxButler
1981 CJ7
Hey LG im installing the cto i ordered... its a really tight fit and its getting really hard to thread it in. Im starting to get woried im going to damage somting if i screw it in further. Is it supposed to be a really really tight fit?
-Knox
post #29 of 201 Old 07-02-2013, 04:50 PM
86cj74.2L
86cj74.2L's Avatar
-Knox
Its a tapered thread. It will tighten up as it gets deeper.
How far in is it? How many threads showing?
Was there a orange or red powder on the threads?
post #30 of 201 Old 07-02-2013, 04:53 PM
LumpyGrits
IIRC, it's either a 1/8" or 1/4" pipe thread, 'rite'?
You may need to get a pipe thread tap, and chase the threads on the Jeep. BTDT many times......
LG
carter carb , cj7 , egr , emissions , vacuum
