CJ7 Carter BBD Vacuum Line Help - Page 14 - JeepForum.com
post #196 of 201 Old 07-10-2013, 04:13 PM Thread Starter
KnoxButler
1981 CJ7
I dont know about the adjusting bit but i had the wheels (both left and right) jacked off the ground and used an adjustable shower curtain rod to hold the break fully compressed. Didnt feel any resistance.
The parking break works fine so, i might be wrong, but i think that the breaks are adjusted but not getting the fluid that they need from the master cylinder. I attempted to bleed the breaks but the ports were clogged with dirt and breaking fluid ran out from around the threads.
Do you think they might just have air in the system? I did notices that the breaks were softer after replacing the front two calipers even after I bled them.
KnoxButler is offline
post #197 of 201 Old 07-10-2013, 07:00 PM
fourbtgait
1930 MK Patriot
You adjust the rear brakes using the little oval slot on the bottom of the backing plate. It might have a metal or rubber grommet over it.
Inside is a "star wheel", that when turn extends the pads in or out. You can use a flat screw driver or a special brake adjusting tool.
Question, did AMC put self adjusting rear brakes on the back that adjust a certain amount when one backs up?
fourbtgait is offline
post #198 of 201 Old 07-10-2013, 07:44 PM
86cj74.2L
86cj74.2L's Avatar
I think the auto adjusters were a safety requirement starting in the late 60's some time. I know my 1968 roadrunner had manual adjusters on all four corners and one garage wouldn't inspect it because of that. (And the loud exhaust anyway)
86cj74.2L is offline
post #199 of 201 Old 07-10-2013, 07:54 PM
LumpyGrits
YUP, they(and MOST)never work worth a dang either.
When you spin the rear wheel, IF the brakes are adjusted 'rite'. You should just barely hear them scrape/drag just a bit.
I still say that you need somedandperson to stand on the brakes for you to test!
LG
LumpyGrits is offline
post #200 of 201 Old 07-10-2013, 09:02 PM Thread Starter
KnoxButler
1981 CJ7
I do hear some, i wouldn't call it scraping, but friction coming from the drums. The wheel dosn't spin supper free it slows down relatively fast.
post #201 of 201 Old 07-10-2013, 10:21 PM
fourbtgait
1930 MK Patriot
LG
Agree, the thought just came to mind.
Also agree with Lumpy you need some one to help. Jack it up, get it spinning, have them stomp the brake.
When you did the front brakes, did you bleed all 4 wheels?
If the bleeders are clogged, any auto parts store has new ones cheap.
Russell
carter carb , cj7 , egr , emissions , vacuum
