CJ7 Carter BBD Vacuum Line Help - Page 13 - JeepForum.com
post #181 of 201 Old 07-09-2013, 04:10 PM
LumpyGrits
Step up 1 size at a time in the main jets.
LG
LumpyGrits is online now
post #182 of 201 Old 07-09-2013, 04:16 PM
86cj74.2L
86cj74.2L's Avatar
LG
? He has a carter.
86cj74.2L is offline
post #183 of 201 Old 07-09-2013, 04:35 PM
LumpyGrits
Originally Posted by 86cj74.2L View Post
? He has a carter.
OH-CRAP.......My CRS 'bloomed' again!
LG
post #184 of 201 Old 07-09-2013, 05:39 PM Thread Starter
KnoxButler
1981 CJ7
I was going to ask how one adjusted the metering jets, as they are just an opening screwed into the carb where the metering rods go into. So what do I do?
KnoxButler is offline
post #185 of 201 Old 07-09-2013, 05:41 PM Thread Starter
KnoxButler
1981 CJ7
I could enrich the mixture without idle problems or loosing vacuum, should I do that until i get a rough idle then turn them back to the last point where it was fine?
post #186 of 201 Old 07-09-2013, 08:14 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Well you could adjust the piston that controls the needle height. Raise it a bit to make it richer, lower it to make it leaner.
But this will only effect your main system, not your idle system. Unless your idling speed is set to high.....
John Strenk is offline
post #187 of 201 Old 07-09-2013, 08:28 PM
fourbtgait
1930 MK Patriot
LG
The pedestal crumbled.......
fourbtgait is offline
post #188 of 201 Old 07-09-2013, 08:41 PM
86cj74.2L
86cj74.2L's Avatar
I still wonder if eliminating the EGR completely will make it happier. Then you know where to go next.
EGR mimics all kinds of other problems. From ignition to the carburetor.
post #189 of 201 Old 07-09-2013, 09:13 PM
John Strenk
1976 CJ5
Probably better none than a leaky one...
The only good EGR is a working EGR...
post #190 of 201 Old 07-09-2013, 09:30 PM
86cj74.2L
86cj74.2L's Avatar
A piece of aluminum cut to length with two holes drilled into it will completely eliminate it as a problem.
post #191 of 201 Old 07-10-2013, 09:28 AM Thread Starter
KnoxButler
1981 CJ7
John - Raising the metering rod like you said had helped me a few days ago when i was having this problem perhaps I could try raising them a little more.
86cj- I do already have a plate i cut to block of the egr, its not installed as i was concerned about its long term survival, I would like to get a egr delete plate. Anyone know where to get one? I think there was a thread on that a while ago.
post #192 of 201 Old 07-10-2013, 01:55 PM Thread Starter
KnoxButler
1981 CJ7
Hey guys another quick question, the other day I was changing out the old calipers for refurbished ones. I lifted the back end up to test the drums in the back and found that they dont engage with the break pedal but work perfectly with the parking break. Is that normal?
post #193 of 201 Old 07-10-2013, 02:06 PM
LumpyGrits
How hard are you push down on the pedal and do you have power brakes?
60%-70% of your braking is in the front.
LG
post #194 of 201 Old 07-10-2013, 02:27 PM Thread Starter
KnoxButler
1981 CJ7
No power breaks and 100% compressed. So im guessing its not normal, because most of the breaking is done in the front anyway should i worry about finding and solving the problem? It would be kinda nice when 4x4 to have all 4 breaks but not necessary.
post #195 of 201 Old 07-10-2013, 03:04 PM
LumpyGrits
First, make sure your rear brakes are adjusted correctly. Then have someone 'stand' on your breaks and see if you can turn the rear wheels with your hands. The rear wheels need to be off the ground for this........
LG
carter carb , cj7 , egr , emissions , vacuum
