CJ7 Carter BBD Vacuum Line Help - Page 11 - JeepForum.com
post #151 of 201 Old 07-05-2013, 10:24 PM Thread Starter
KnoxButler
1981 CJ7
Could I just put a vacuum line with a smaller diameter instead?
KnoxButler is offline
post #152 of 201 Old 07-06-2013, 03:53 AM
86cj74.2L
86cj74.2L's Avatar
For what its worth take the whole thing apart and clean all the carbon out. Its comes apart in a few pieces.
86cj74.2L is offline
post #153 of 201 Old 07-06-2013, 04:10 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by LumpyGrits View Post
EGR is held on w/2 bolts.
John, your lucky you didn't lose the spring
LG
Not so lucky,
after I saw your warning to me I went back out and it was gone.
fortunately, I have a bunch of BBD carbs around here ......
John Strenk is offline
post #154 of 201 Old 07-06-2013, 04:33 AM
John Strenk
1976 CJ5
Originally Posted by KnoxButler View Post
Found said hole, how do get/make a smaller one?
Here is one way,
pick a washer with a smaller hole....
and stake it in place.
If your NOx readings are very low, i would just cut out a gasket without any holes in it and mount the EGR valve. it would pass visual that way but not work. The gasket will not last forever though.
or put a plug inside the vacuum line so no vacuum would reach the EGR.
as 86... mentions. Just clean it. It might not be seating properly causing a leak at idle.
post #155 of 201 Old 07-06-2013, 09:22 AM Thread Starter
KnoxButler
1981 CJ7
On my egr there is a tube almost that comes out of the egr and into the manifold, it has two notches on eather side that make it almost seem like you could unscrew it but iv had no luck getting it off? Any ideas?
PS: How do you "steak it on"
post #156 of 201 Old 07-06-2013, 10:34 AM Thread Starter
KnoxButler
1981 CJ7
Is there a reason that I just couldn't limit the vacuum with a smaller diameter line?
post #157 of 201 Old 07-06-2013, 11:10 AM
LumpyGrits
Smaller line still gives the same vac. just a bit slower is all to load.
LG
LumpyGrits is offline
post #158 of 201 Old 07-06-2013, 11:45 AM Thread Starter
KnoxButler
1981 CJ7
Ok got it, so any idea how I can get that crown thing off so I can put washers on to make it smaller?
post #159 of 201 Old 07-06-2013, 12:23 PM
86cj74.2L
86cj74.2L's Avatar
If I remember correctly that EGR valve comes apart in two or three pieces. I really think the different sections just thread together.
post #160 of 201 Old 07-06-2013, 01:16 PM Thread Starter
KnoxButler
1981 CJ7
I disconnected the egr from the cto and plugged it and now its still almost stalling. It doesnt happen when I rev it up only when i give it some gas to start from a stop.
The engines running perfectly smooth, I messed around with the floats, the timing, the egr. Nothing is helping the problem?
post #161 of 201 Old 07-06-2013, 01:51 PM
John Strenk
1976 CJ5
The EGR could of been full of carbon and once you started to make it work again, some of that carbon build up could of come loose and is now keeping it open all the time.
post #162 of 201 Old 07-06-2013, 01:57 PM Thread Starter
KnoxButler
1981 CJ7
It feels like its closed all the way, I dont want to pay 80 bucks to get a new one and I cant seem to get it apart without bending the edge open.
post #163 of 201 Old 07-06-2013, 02:41 PM Thread Starter
KnoxButler
1981 CJ7
If i depress the diaphragm and plug the vacuum port with my finger it slowly returns to the closed position. Does that mean its bad?
post #164 of 201 Old 07-06-2013, 06:27 PM
John Strenk
1976 CJ5
Good question. I'm not sure. off hand I would say there is a leak someplace. Some of those hold vacuum forever.
The real problem is if the part that seals off the intake is clean and not leaking.
If you have some gasket sheets, you can cut it to block off the EGR as a test. NAPA sells gasket sheets. Get a thick one.
post #165 of 201 Old 07-08-2013, 03:47 PM Thread Starter
KnoxButler
1981 CJ7
Hey guys I PASSED! I had to adjust the pump travel and the metering rods to get it to not flood. But I passed!
Thank you all so so much! You guys have all helped very much!
Soon im going to start a bild/restoration thread for my Jeep where ill be asking questions about paint, dash board guages (John Strenk ), etc. Ill also be posting pictures of my progress.
Quick question, iv noticed that the only way i can keep the engine from flooding is to have the choke pulled out a little bit. Is it normal for the carb to like the choke closed off a bit? or do i need to re tune it again, if so what do i need to adjust?
carter carb , cj7 , egr , emissions , vacuum
