CJ7 Carter BBD Vacuum Line Help - JeepForum.com
post #1 of 201 Old 06-25-2013, 03:05 PM Thread Starter
KnoxButler
1981 CJ7
Ok I'm totally lost here and this is my SOS/distress call. My 81 CJ7 258 somehow has a Carter BBD without the stepper motor, no computer, etc.
My problem is, I'm trying to hook up the vacuum lines as proper as I can, but when i try to follow the diagrams I found online im missing some of the stuff such as a CTO or ported vacuum switch also no sol vac.
Im completely lost and haven't been able to get anywhere with research online.
How do I hook up the EGR?
-Knox
KnoxButler is offline
post #2 of 201 Old 06-25-2013, 03:09 PM Thread Starter
KnoxButler
1981 CJ7
It would be helfull to have a layout of the ports on my non stepper motor carter carb. If anyone has one.
-Knox
post #3 of 201 Old 06-25-2013, 03:26 PM
LumpyGrits
LumpyGrits is offline
post #4 of 201 Old 06-25-2013, 03:35 PM Thread Starter
KnoxButler
1981 CJ7
The problem im having is that half of the stuff on this diagram doesnt exist on my engine.
-Knox
post #5 of 201 Old 06-25-2013, 07:43 PM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
-Knox
Knox,
post a picture of what you do have in the engine compartment, left side, right side, straight on, even underneath could be helpful. That 1981 factory service manual is looking better and better all the time... Check your PM's. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #6 of 201 Old 06-26-2013, 02:44 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yeah, don't even try to match up a BBD with a stepper BBD. there were a lot of changes in emissions laws between those years. Plus the added bonus of infant computer control.
Do you have an aluminum intake or steel intake? Makes a difference.
Here is a great link.
http://www.autozone.com/autozone/rep...46822&cmpid=cj
Here is a picture from that page:
Notice this was one of those years that the distibutor vacuum advance switched between maifold vacuum and ported vacuum depending upon engine temp.
Basically the thing to remember is, the EGR has to be connected ported vacuum and the CTO.
John Strenk is online now
post #7 of 201 Old 06-30-2013, 08:31 AM
Jon In Tucson
1983 CJ5
Knox,
Haven't heard anything for a few days. How goes the battle? Are you figuring out the vacuum hose routing for your year of CJ? Keep plugging away... God bless.
Jon In Tucson
panic." - Mike
post #8 of 201 Old 06-30-2013, 05:16 PM
monahannl
Vac Line issues
I am having similar issues, I recently took out my 2.5L and installed a 72' 4.2L inline six. It has the stock Carter carb and alum intake. I just rebuilt the carb this morn and put it back on. I can't get the thing to do anything but idle rough. I have all the vac lines plugged off except for the advance to the HEI dizzy. Timing was statically timed, exhaust is unfinished, but should start and run at least. I believe I am having carb issues because there is little else to go wrong.
1. am I missing something on the vac lines? should I be hooking up something other than the vac advance to get it to run?
2. What fuel pressure is optimum for the Carter BBD?
monahannl is offline
post #9 of 201 Old 06-30-2013, 06:33 PM
86cj74.2L
86cj74.2L's Avatar
What are your fuel screws set to?
How did you set your float height?
86cj74.2L is online now
post #10 of 201 Old 06-30-2013, 07:22 PM Thread Starter
KnoxButler
1981 CJ7
UPDATE: I rebuilt the carb as Jon In Tucson advised and it worked beautifully! Smooth idle and smooth at high rpms.
However I still have yet to do a full replacement of the vacuum lines because of a lack of a CTO or "ported vacuum switch" as a great deal of the important things were routed to it or from it. So I have ordered the part from Autozone and as soon as it gets here ill set to work on replacing all the lines.
-Knox
post #11 of 201 Old 06-30-2013, 07:31 PM Thread Starter
KnoxButler
1981 CJ7
Iv got a few threads on this problem that I had so to recap what I did to solve it was:
-Team rush upgrade: 78 ford f100 cap and plugs with a adapter, as well as new plugs.
-I cleaned out the venturi really good with cleaner and a fine needle (before I decided to do a full rebuild, helped with idle)
-Full rebuild of the carb. It wasn't all that dirty in fact it looked like it had recently been rebuilt leading me to believe that it was the settings that were causing my problem so I made sure to accurately adjust everything to stock settings. i.e the step up piston, the pump travel, and float level (I have a hunch the float level was way to low on my carb.)
On a side note does anyone know what the baffle that goes right behind the floats does? Mine didn't have one although there is one in the exploded view of the carb. Is it worth replacing or does it just stop the flow of gasoline behind the floats?
-Knox
post #12 of 201 Old 06-30-2013, 09:32 PM
monahannl
I set the float according to the instructions, fuel screws same.
post #13 of 201 Old 06-30-2013, 10:06 PM
86cj74.2L
86cj74.2L's Avatar
How many turns out after you set them to the lean best idle?
post #14 of 201 Old 07-01-2013, 04:11 AM
John Strenk
1976 CJ5
-Knox
On mine it keeps the float hinges in place.
post #15 of 201 Old 07-01-2013, 08:35 AM Thread Starter
KnoxButler
1981 CJ7
Sorry I'm confused, on my carb. there is a piece of metal like an inverted u that holds that little pin that the floats pivot on in place.
-Knox
carter carb , cj7 , egr , emissions , vacuum
