-   -   CJ7 Carter BBD Vacuum Line Help (http://www.jeepforum.com/forum/f8/cj7-carter-bbd-vacuum-line-help-1541274/)
KnoxButler 06-25-2013 03:05 PM
Ok I'm totally lost here and this is my SOS/distress call. My 81 CJ7 258 somehow has a Carter BBD without the stepper motor, no computer, etc.
My problem is, I'm trying to hook up the vacuum lines as proper as I can, but when i try to follow the diagrams I found online im missing some of the stuff such as a CTO or ported vacuum switch also no sol vac.
Im completely lost and haven't been able to get anywhere with research online.
How do I hook up the EGR? :confused::confused:
-Knox
KnoxButler 06-25-2013 03:09 PM
It would be helfull to have a layout of the ports on my non stepper motor carter carb. If anyone has one.
-Knox
LumpyGrits 06-25-2013 03:26 PM
http://home.sprynet.com/~dale02/vacuhose.htm
Home site.....
http://home.sprynet.com/~dale02/list.htm
LG
KnoxButler 06-25-2013 03:35 PM
The problem im having is that half of the stuff on this diagram doesnt exist on my engine.
-Knox
Jon In Tucson 06-25-2013 07:43 PM
-Knox
Knox,
post a picture of what you do have in the engine compartment, left side, right side, straight on, even underneath could be helpful. That 1981 factory service manual is looking better and better all the time... Check your PM's. God bless.
Jon In Tucson
John Strenk 06-26-2013 02:44 AM
603 Attachment(s)
Yeah, don't even try to match up a BBD with a stepper BBD. there were a lot of changes in emissions laws between those years. Plus the added bonus of infant computer control.
Do you have an aluminum intake or steel intake? Makes a difference.
Here is a great link.
http://www.autozone.com/autozone/rep...46822&cmpid=cj
Here is a picture from that page:
http://repairguide.autozone.com/znet...5280252406.gif
Notice this was one of those years that the distibutor vacuum advance switched between maifold vacuum and ported vacuum depending upon engine temp.
Basically the thing to remember is, the EGR has to be connected ported vacuum and the CTO.
Jon In Tucson 06-30-2013 08:31 AM
Knox,
Haven't heard anything for a few days. How goes the battle? Are you figuring out the vacuum hose routing for your year of CJ? Keep plugging away... God bless.
Jon In Tucson
monahannl 06-30-2013 05:16 PM
Vac Line issues
I am having similar issues, I recently took out my 2.5L and installed a 72' 4.2L inline six. It has the stock Carter carb and alum intake. I just rebuilt the carb this morn and put it back on. I can't get the thing to do anything but idle rough. I have all the vac lines plugged off except for the advance to the HEI dizzy. Timing was statically timed, exhaust is unfinished, but should start and run at least. I believe I am having carb issues because there is little else to go wrong.
1. am I missing something on the vac lines? should I be hooking up something other than the vac advance to get it to run?
2. What fuel pressure is optimum for the Carter BBD?
86cj74.2L 06-30-2013 06:33 PM
What are your fuel screws set to?
How did you set your float height?
KnoxButler 06-30-2013 07:22 PM
UPDATE: I rebuilt the carb as Jon In Tucson advised and it worked beautifully! Smooth idle and smooth at high rpms.
However I still have yet to do a full replacement of the vacuum lines because of a lack of a CTO or "ported vacuum switch" as a great deal of the important things were routed to it or from it. So I have ordered the part from Autozone and as soon as it gets here ill set to work on replacing all the lines.
-Knox
KnoxButler 06-30-2013 07:31 PM
Iv got a few threads on this problem that I had so to recap what I did to solve it was:
-Team rush upgrade: 78 ford f100 cap and plugs with a adapter, as well as new plugs.
-I cleaned out the venturi really good with cleaner and a fine needle (before I decided to do a full rebuild, helped with idle)
-Full rebuild of the carb. It wasn't all that dirty in fact it looked like it had recently been rebuilt leading me to believe that it was the settings that were causing my problem so I made sure to accurately adjust everything to stock settings. i.e the step up piston, the pump travel, and float level (I have a hunch the float level was way to low on my carb.)
On a side note does anyone know what the baffle that goes right behind the floats does? Mine didn't have one although there is one in the exploded view of the carb. Is it worth replacing or does it just stop the flow of gasoline behind the floats?
-Knox
monahannl 06-30-2013 09:32 PM
I set the float according to the instructions, fuel screws same.
86cj74.2L 06-30-2013 10:06 PM
How many turns out after you set them to the lean best idle?
John Strenk 07-01-2013 04:11 AM
603 Attachment(s)
-Knox
On mine it keeps the float hinges in place.
KnoxButler 07-01-2013 08:35 AM
Sorry I'm confused, on my carb. there is a piece of metal like an inverted u that holds that little pin that the floats pivot on in place.
-Knox
The time now is 10:28 AM.
