cj7 build, pics - JeepForum.com
post #1 of 20 Old 07-21-2010, 11:51 AM Thread Starter
dirtdonthurt
cj7 build, pics
- found a rust-free cj7
- yanked the body and cleaned everything up, replaced seals
- sprayed bedliner inside the tub and fenderwells
- rebuilt the dana 300 & put on rear discs
- overhauled the motor
- yj springs, SOA, 1" body, bilstein shocks
- hei, weber carb, aluminum radiator & elec fan
- astrovan hydroboost with russell ss hoses and adapters
- dual optimas with perko switch, warn isolator, 100a alternator, etc.
- built the cage and painted to match
- built the dash (drew it on CAD and had it cut on a CNC laser)
- installed auto meter gauges, led's, marine stereo, etc.
theres a ton of other stuff not listed. i spent every dollar and every night for 3mos working on this thing. just a couple of big-ticket items left to do (tires, lockers) tell me what y'all think
iPhone pics 017.jpg   iPhone pics 162.jpg   iPhone pics 108.jpg   iPhone pics 158.jpg   iPhone pics 166.jpg
dirtdonthurt is offline
post #2 of 20 Old 07-21-2010, 01:10 PM
lou h
1979 CJ5
Excellent work... beautiful result. Congrats!
Dirty Juice II
lou h is offline
post #3 of 20 Old 07-21-2010, 01:20 PM
CajunCJ
Very Nicely done !!
I don't know much about SOA lifts, but are the springs supposed to be that flat? There's no arch to them at all.
If you're close to the Lafayette area I wouldn't mind taking a look at that thing, it's sweet.
CajunCJ is offline
post #4 of 20 Old 07-21-2010, 01:33 PM
82JeepCJ7
1982 CJ7
That is the beauty of a SOA. The spring is flat so it will flex up and down. That is why you get way more articulation from a SOA than a SUA.
What program did you use for your dash? I have one that is the basic dash with the steering wheel cut out in .DXF format.
82JeepCJ7 is offline
post #5 of 20 Old 07-21-2010, 01:40 PM Thread Starter
dirtdonthurt
thanks and yes, theyre supposed to be pretty flat, but not that flat. i believe they are worn slap out. im going to be trying a pair of rear yj springs in the front in the next couple of days.
i'm located in central, just north of BR, not to far from laffayette
post #6 of 20 Old 07-21-2010, 01:43 PM Thread Starter
dirtdonthurt
i drew it on fastcad and converted it to dxf. i started out with a dxf that i found on the net that had the bolt holes and steering column but the bolt holes were a little off.
post #7 of 20 Old 07-21-2010, 02:00 PM
jp360cj
1977 CJ7
looks great!! what's the thing on the transmission shifter?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #8 of 20 Old 07-21-2010, 02:06 PM
motiv8ya
1979 CJ7
Very nice work, I like the dash and gauges mounted to the crossbar. You made quick work of that thing in only three months.
motiv8ya is offline
post #9 of 20 Old 07-21-2010, 02:34 PM
82JeepCJ7
1982 CJ7
That dash DXF you got off the net, is it from Trailslesstraveled?
post #10 of 20 Old 07-21-2010, 02:35 PM
82JeepCJ7
1982 CJ7
JP, thats the winch controller.
post #11 of 20 Old 07-21-2010, 03:15 PM Thread Starter
dirtdonthurt
yep. thats the one. i just got rid of the 'ears' that are supposed to break over at the top and bottom, widened the bolt holes to .4375", and drew in all the rest of my stuff.
and yes thats for the winch. don't know if i like it there yet.
post #12 of 20 Old 07-21-2010, 03:17 PM
82JeepCJ7
1982 CJ7
I used the same program to burn out two dashes. One went in my CJ7, the other went in my friends 67 CJ5. I had to do a little "tweaking" also.
post #13 of 20 Old 07-21-2010, 03:19 PM
countryman247
1979 CJ7
where did you get the roll bar?
countryman247 is offline
post #14 of 20 Old 07-21-2010, 03:26 PM Thread Starter
dirtdonthurt
i built the front half out of 2" and welded it to the factory roll bar. i'm pretty sure they sell a pre-bent kit that you weld together yourself for a couple hundred bucks
post #15 of 20 Old 07-21-2010, 03:37 PM
82JeepCJ7
1982 CJ7
351w Build pics and axle questions mfeldman21 Jeep CJ Forum 0 11-07-2009 01:37 PM
Progress on build pics and a question My1978CJ7 Jeep CJ Forum 4 06-23-2008 07:47 PM
76 CJ build up with pics ONEMORE2 Jeep CJ Forum 18 01-05-2008 06:09 AM
**DEBATE** Build up cj2a or buy and build up cj5 Kevin Swayze Jeep CJ Forum 4 02-06-2002 02:07 PM
