cj7 body repair-rivet/tack weld spot fix - JeepForum.com
post #1 of 10 Old 05-24-2006, 08:34 PM Thread Starter
CJ7 Vette
as all cj owners know...looking down the side of the jeep on the rear quarter you see a nice long succession of dimples. I am about to strip/prep/repaint my cj7 and im wondering the best method to fill those areas for a nice "straight body" look.
I worry about using a bondo type filler and having it pop off a year or two down the road. any suggestions would be appreciated! thanks, Dave
84 CJ7 new 258,Howell TBI, Borla header/exhaust, clutch, repainted engine compartment,frame and most of undercarriage,jks discos and a host of other new stuff under the hood :)
update: no rust, new floors, stripped, primed, filled, blocked, and repainted with PPG Concept Garnet Metallic. Hardtop freshly painted, all trim painted in black metallic with a bit of flatener mixed in. New seats, carpet, console, roll bar pad, seat belts,dash, flares, windshield, seals, tire carrier and more!
CJ7 Vette is offline
post #2 of 10 Old 05-25-2006, 10:52 PM
thiswebs4u
Why not just get a cheap wire feed flux welder?
1979 CJ-7, Chevy 350, edelbrock 600 cfm, mild rv cam, T18A, D30 front D44 back (locked).
2004 Grand Cherokee Limited.
2004 PSD Superduty 4x4 supercab shortbed.
thiswebs4u is offline
post #3 of 10 Old 05-26-2006, 05:03 AM
Brandon11130
yes x2 on that, you will thank yourself in the end and you will save a ton of money. plus it is a lot easier to weld somthing when its convenient for you, not calling up one of your friends, or leaving your car at a welding shop for days. i say just buy a welder.
1959 JEEP CJ5
We do not ask for your poor or your hungry. We do not want your tired and sick. It is your corrupt we claim. It is your evil that will be saught by us. With every breath we shall hunt them down. Each day we will spill their blood ‘til it rains down from the skies.
Brandon11130 is offline
post #4 of 10 Old 05-26-2006, 05:21 AM
jeepduo
1978 CJ7
wrap the rear in diamond plate. Seen several like this, can be made to look pretty good.
1978 CJ7, Driving, but never finished
jeepduo is offline
post #5 of 10 Old 05-26-2006, 03:14 PM Thread Starter
CJ7 Vette
guess I could flux weld it...didnt think of that. dad has a couple welders and the skill to go with them so maybe I will hit him up for some help thanks!
post #6 of 10 Old 05-27-2006, 08:33 AM
ttrem
err what would flux welding do? Would it fill the dimples like a bondo would except its metal?
1986 CJ-7 w/ 4.0HO FI, 4" lift, 1" body lift on 35" Super Swampers, AX-15, and a girly sounding horn =(
ttrem is offline
post #7 of 10 Old 05-28-2006, 08:18 AM
Galt
Galt's Avatar
1983 CJ7
I doubt that body filler would pop out that easily so long as the parts are joined tightly. If your just filling in dimples like you say the body filler should work nicely.
However if you would rather not use it there is always the lead filler which is metal, almost just as easy to work with and will most certainly not lift or chip out.
Here is a link to a decently priced "starter" kit that should be enough to get the job done.
Good luck.
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #8 of 10 Old 05-28-2006, 10:54 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If done correctly, body filler would be fine to fill in those little dimples. If you want to fill them with weld, use gas and .025" solid wire to keep heat (distortion) down. Flux core bought from the local hardware store will be .035" or .030"... those will require too much heat for sheetmetal work... and will require a touch of filler in the end anyway.
BESRK is offline
post #9 of 10 Old 05-28-2006, 11:37 AM Thread Starter
CJ7 Vette
after stripping my interior and really looking for where I have rust, I have decided to just tub swap instead of chasing rust. for someone with decent welding skills this tub would be fine but with my limited skills in bodywork it would be a nightmare and very time consuming. both rockers and passenger quarter need work and front floorpans need changed out. this jeep spent 3 years in cleveland before I bought it...and it is now showing the effects of that lol. probably just going to go fiberglass and be done with it. thanks for all the replies everyone, the wealth of knowledge on this site is astounding!
post #10 of 10 Old 05-28-2006, 01:22 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
CJ7 Vette I just sent you an interesting PM...
BESRK is offline
Soft spot at rear cross member-Repair Question jpd1899 Jeep CJ Forum 1 01-24-2010 03:24 PM
Weld keeper nuts for body mounts? namredla Jeep CJ Forum 1 03-04-2009 08:38 PM
CJ 7 rusty floorboards. What to do? Body filler? Weld metal in? danattherock Jeep CJ Forum 7 01-31-2009 10:59 AM
Jeep CJ Body Weld Help JeepyMcJeeprson Jeep CJ Forum 0 01-22-2008 01:44 PM
body repair DanAbnormal Jeep CJ Forum 5 02-09-2004 07:18 AM
