CJ7 Battery cutoff switch. - Page 2 - JeepForum.com
post #16 of 17 Old 01-23-2014, 11:51 PM
BagusJeep
1981 CJ7
Southerngypsy has the same idea as me. I have these on the dash of Bagusjeep and Puthijeep near the ignition with the key wired to the key ring. When I am away from the vehicle I know all power is disconnected and can leave it for weeks if need be, no electrical fires and no discharged batteries. If you want to preserve the radio memory you can wire around it through a small fuse direct to the radio.
It needs a new set of cables from battery to switch and from switch to solenoid but there is enough space behind the dash to get it in.
Gladys will be getting the same arrangement in a few weeks.
I would not recomemnd this if you have a winch, the switches I use would not be rated high enough.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #17 of 17 Old 01-24-2014, 12:33 AM
SouthernGypsy
De Oppresso Liber
SouthernGypsy's Avatar
You can use them with a winch but just wire your winch direct to the battery (which it should be anyway).
~ SouthernGypsy's Jeeps ~
2004 Jeep TJ Rubicon 4.0L/Automatic
1983 Jeep CJ-7 Limited 4.2L/5 Speed
SouthernGypsy is offline
battery
