CJ7 Axle Maintenance - JeepForum.com
post #1 of 2 Old 11-22-2012, 06:42 PM Thread Starter
highred
1979 CJ7
This weekend I am beginning my '79 CJ7 off-frame restoration. I plan to replace all of the u-joints, open up the differentials, go through the brakes, etc.
Is there anything I should do to the axles beyond just replacing the gear oil? Should the axles be checked out? Are there any seals I should replace?
I do not know what the Axles are right now. I am assuming they are AMC 20 on the front and Dana 30 on the rear.
(Please keep replies in laymen terms)
Thanks!
Rob Caldwell
highred is offline
post #2 of 2 Old 11-24-2012, 09:27 PM
agear
It would be amc 20 in the rear and dana 30 in the front.if the seals are'nt dry and cracked up and or leaking dont replace. put some grease on the seal rubber lip. Depends on how far you want to go with it................
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
