CJ7 Accumulator Drier question - JeepForum.com
post #1 of 4 Old 05-02-2010, 10:51 PM Thread Starter
Johnyakimo1855
Guys I am having trouble finding the rite accumulator drier for my CJ with the factory condensor. All the ones I am finding are missing the L shaped bracket welded to the drier that allows you to screw it to the condensor. I have the Flare to Flare style. Anyone run into this and have a solution or maybe a prt number or supplier??? Thanks
Johnyakimo1855 is offline
post #2 of 4 Old 05-02-2010, 11:04 PM
only in a jeep cj
IS this the OEM unit your asking about?
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 4 Old 05-02-2010, 11:37 PM Thread Starter
Johnyakimo1855
yes it is the factory american air setup. Sorry about that. You see how the upper condenser has the drier with that little L shaped bracket on it for the screws to go through. None of the ones I am finding have that.
post #4 of 4 Old 05-03-2010, 12:01 AM
only in a jeep cj
When I did the stroker swap into my 86, I swapped in the whole AC system from a YJ do to the belt/compressor and avaibility of parts from the 87 up and LACk thereof for the 86 back. I'm swapping the whole CJ set up into a Scrambler, but yes, I too couldn't find parts, namely the correct late CJ condenser in the pictures above. The tube is part of it and would be a pain for aftermarket suppliers to make/ ship/store. I would use a YJ dryer (or one like the CJ) and carefully spot weld the bracket on to match the condenser IF yours is in good shape.
Ed
1975 CJ-6 1983 CJ-8
New lift question - shackle angle question *Thunder Jeep CJ Forum 2 10-09-2009 08:53 AM
Timing question & adjusting carb question. jatepper Jeep CJ Forum 8 02-22-2009 08:29 PM
Pre-Oiler or accumulator Faceplant Jeep CJ Forum 5 04-10-2008 08:07 AM
Computer question and FUEL INJECTION question MontyWilco Jeep CJ Forum 4 10-11-2006 09:21 PM
