CJ7/8 Stock Fog/Driving Light Hook Up - Not Working - JeepForum.com
post #1 of 8 Old 11-08-2011, 11:28 PM Thread Starter
Rollbar
1984 CJ8
I have a stock set of these and I have good grounds as well.
The set (lights) works, I tested them on the battery before I mounted the bumper.
Black=ground
Red=hot
The red wire hooked to the red pig-tail on the drivers side harness (factory connection) behind the headlight.
I did test the red feed wire w/a test light (it works/tested it on battery) w/the new headlight switch to full on (like if you were driving at night) and the test light did not work.
I did look for a fuse but couldn't find anything noting a driving light or ... All fuses are good, but maybe I'm missing something.
Are the lights hook up correctly (I've never had a factory install for this set up) and does anyone have any info on this factory set up.
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #2 of 8 Old 11-08-2011, 11:57 PM
only in a jeep cj
If you want it stock? Do you have the correct dash switch and the harness that goes with it? it has a relay and ties into the headlight switch and only powers the fog lights on low beam.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 8 Old 11-09-2011, 04:43 AM
bobbysjeep
1984 CJ8
That's correct, the factory fog light switch/relay plugs into the wiring harness just below the head light switch.
bobbysjeep is offline
post #4 of 8 Old 11-09-2011, 03:34 PM Thread Starter
Rollbar
1984 CJ8
Stock would be nice. Nope, I don't have a switch, thought it was just in the circuit.
<----Click
<---- Click
Rollbar is offline
post #5 of 8 Old 12-01-2011, 04:00 PM Thread Starter
Rollbar
1984 CJ8
OK, the stock set up was big $$ from a PO.
So, I bought a switch/fuse/wire.
The lights are plugged in behind the grill (red lead) and grounded.
Question, is there a way to pick up the HOT lead to the lights under the dash so I can make them work?
I don't know which wire to look for, anyone have a pic?
Thanks,
Jim
If all else fails, I can run a HOT wire to the harness on the finder and splice it there.
<----Click
<---- Click
Rollbar is offline
post #6 of 8 Old 12-01-2011, 05:00 PM
bobbysjeep
1984 CJ8
Thanks,
Jim
The switch assembly (switch, relay, plug) plugs directly into the factory harness just behind the head light switch. If you look under the dash in that general area you should see the flat 4 wire plug hanging there. It sounds like you have the other end hooked up correctly. If you still can't find it I will take a picture of mine under the dash.
post #7 of 8 Old 12-01-2011, 07:09 PM Thread Starter
Rollbar
1984 CJ8
Thanks, got it all working.
Jim
<----Click
<---- Click
Rollbar is offline
post #8 of 8 Old 12-02-2011, 03:34 AM
bobbysjeep
1984 CJ8
Glad to help.
Led Driving Light seemakashyap Jeep CJ Forum 0 09-22-2011 03:44 AM
Tac Connections/Hook Up on Stock Wiring Harness Rollbar Jeep CJ Forum 5 02-04-2011 04:34 PM
After market shift light hook-up jwatson911 Jeep CJ Forum 6 03-21-2010 04:23 AM
CJ-5 towing tail light hook up dbd Jeep CJ Forum 3 08-24-2008 10:48 AM
Back-Up Light/ 4wd hook-up? Kevmatic Jeep CJ Forum 7 05-28-2007 01:51 PM
