Cj7 4.0/aw4/d300 fit? - JeepForum.com
post #1 of 7 Old 04-22-2012, 10:50 AM Thread Starter
topherbarrow
Hey guys,
I am finally ready to upgrade the engine in my 81 cj7(258/t4/d300), and after weighing all of the options have decided on the 4.0 w the aw4 mated to my existing d300.
I have read many threads on this swap, but have not found anything on the figment inside of the vehicle. I am worried that when I gonw the longer aw4 tranny that the TC shifter will be pushed back and I will have to chop up my floor in order for the shifter to come up.
Does anyone have any insight into this or even some post install pics?
Any input will be greatly appreciated!
topherbarrow is offline
post #2 of 7 Old 04-22-2012, 10:59 AM
-jeep-jeep-
1983 CJ7
Although i cant actually answer your question as i have never done the swap, if it does move the shifter back and you dont want to cut the tub (and have some cash) these are a good option HERE
Jeep # 1 -
- Restoration in progress...very slow progress
Jeep # 2 -
- 31x10.5R15 Pro Comp Extreme mt's - 4.0 HO head - MC2100
Jeep # 3 - 1990 Cherokee - 4.0, AW4, dana 30 HP, dana 35 -31x10.5 R15 mud terrains, 2" PNP lift.....Gone to the crusher
Jeep # 4 - 1999 wj stock and still pretty
-jeep-jeep- is offline
post #3 of 7 Old 04-22-2012, 11:42 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Don't forget the twin sticks that's needed to run the cables
LT1CJ7 is offline
post #4 of 7 Old 04-22-2012, 05:56 PM
only in a jeep cj
That is the same swap I'm will do later in my 86 CJ. From what I have measured, once you drill the new holes on the AW4 or use a clocking ring, the t- case is about 2 inches further back (than my T5). I too don't want to cut the floor as I have the factory console there. So what I'm doing is moving the t case pivot forward and extending the two shift rails with bar stock of the same size. It will them come up in the old location and shift the same. You'll need some fab tool/ skill though as it's all custom.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #5 of 7 Old 04-27-2012, 01:41 AM Thread Starter
topherbarrow
Thanks for all of the help, guys! I'll definitely be checking into a few of these items.
post #6 of 7 Old 04-27-2012, 03:33 AM
gmakra
I have the NW cable kit and while it works as advertised I am not that thrilled with it. Cable shifting the 300 is awkward it since it muffles the feeling of the dentents
gmakra is offline
post #7 of 7 Old 04-27-2012, 07:03 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Ah, So your the type that likes it rough
LT1CJ7 is offline
4.0 , 4.0 swap , aw4 , cj7 , engine swap
T18, D300 and 360 rconner Jeep CJ Forum 15 01-03-2010 01:22 PM
What came with D300 BigTDog Jeep CJ Forum 2 12-10-2008 08:19 PM
d300 id natehate Jeep CJ Forum 5 05-20-2007 10:12 PM
cj7=d300? jeepsteads Jeep CJ Forum 6 02-19-2007 10:24 AM
D300 - how can you tell if it has 4:1 or not? SomerJeep Jeep CJ Forum 6 07-06-2006 06:10 AM
