CJ7 258 exhaust question - JeepForum.com
post #1 of 3 Old 08-11-2007, 01:17 PM Thread Starter
n3480h
Removing my old exhaust system, I had a smaller tube coming off the downtube. The smaller tube bends toward the passenger side and up to what appears to be some sort of valve. The valve partitions part of the exhaust gas back to the air intake. The tube I took off had about 10 holes in it, so I know it was not working properly.
I am guessing its purpose was to recirculate unburned exhaust back through the carb in hopes that it would burn on its second trip through the engine. Doesn't make a lot of sense. Anyway, do I need it? What is its correct name if I were to get a replacement? Or should I just weld the tap on the new downtube shut (no emissions testing here).
Good Lord, this game is expensive!
Building a new '83 CJ7 one part at a time.
n3480h is offline
post #2 of 3 Old 08-11-2007, 02:22 PM
jadams68
jadams68's Avatar
It's called the Pulse Air System and that thing is a Pulse Tube and yes you're correct, it circulates o2 into the exhaust stream to lean out your NO2 emissions.
If you live in a county that requires Emissions, you'll need it to pass. If not, cut it off and weld the bung shut where it enters your Cat.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 3 Old 08-11-2007, 02:45 PM Thread Starter
n3480h
Thank you! Woo Hoo, I get to practice more welding! I like it. Not a great welder, but I've successfully welded in steel body patches, so I should be able to handle that nipple.
(Hee hee. I said "handle that nipple" on the Jeep forum!)
Thanks jadams
n3480h is offline
exhaust question hattrick Jeep CJ Forum 3 01-21-2009 09:37 PM
Exhaust question JeromyCJ7 Jeep CJ Forum 1 03-06-2007 05:55 PM
cj exhaust question SouthernNV_jeep Jeep CJ Forum 3 11-30-2006 11:39 AM
exhaust question 2cjs Jeep CJ Forum 2 07-09-2004 04:14 PM
304 exhaust question possum398 Jeep CJ Forum 7 07-08-2003 12:06 PM
