CJ7 - 258 exhaust manifold - to - collector studs - JeepForum.com
post #1 of 10 Old 08-18-2007, 06:09 PM Thread Starter
obscurotron
The shop that worked on my Jeep did a piss-poor job of putting things back together.
I need a new (preferably longer, too) stud that runs from the flange on the bottom of the exhaust manifold through the flange on the exhaust collector pipe. One of them is in there OK, but the rearward one was barely finger tight and come out in my hands. Where can I order one or two? My google-fu failed me.
At least I found my exhaust leak. I realize this would be the 'wrong' way to fix it, but would a long bolt and nut (stainless) suffice instead?
obscurotron is offline
post #2 of 10 Old 08-18-2007, 06:25 PM
n3480h
I just fought this battle. Snapped off both studs attempting to unbolt the downtube. Wound up drilling them out - not a great deal of fun. Had to use a 16" long 3/8" bit. I replaced mine with 3/8" stainless bolts. I don't know if there is a drawback to this or not, but they are working fine so far. I dipped them in antiseize just in case.
Good Lord, this game is expensive!
Building a new '83 CJ7 one part at a time.
n3480h is offline
post #3 of 10 Old 08-18-2007, 06:39 PM
SuB8HaVeN
I had my gearhead friend that builds drag cars come help me on this issue. I was having the same problem to where some lazy a** installed new exhaust and didn't tighten one of the studs. We had to use a torch to heat the stud/bolt up until they were glowing red, then we were able to take them off. I strongly do not recommend using stainless in this application. I would either go grade 5/8 steel, but preferably, I would recommend going to an auto parts store or exhaust shop and buy some new studs. That's what I did; Auto Zone had everything I needed.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #4 of 10 Old 08-18-2007, 08:42 PM
Bard
Well if it was loose, did you try to tighten the nut first? The exhaust flange bolts use a splined setting carrige bolt into the exhaust frame and donut, then have the nut which I think is called a oblong nut, like a lock washer nut. Name passes me right now. Even with the splines stripped they will tighten. I think a short 9/16 wrench works well at the top. I usually use 2 12" 3/8 extensions, a swivel extension and a 9/16 socket with an impact to get to the nut to tighten it, loosen the outside first a little bit and then tighten the inside first, then go back a snug the outside. If you need a new one or used one, I might have one in my shop, gotta look though. Q-track and 4wd have them as well.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #5 of 10 Old 08-18-2007, 09:09 PM Thread Starter
obscurotron
I actually found the right 3/8 stud at OSH, but it will NOT thread into the manifold. The monkey's cross-threaded it bad. I ended up getting a stainless 5/16 nut and bolt and cranked it the hell down, then tightened up the good stud (frontmost one). So far, it's much better. Might be leaking a little, but I can't feel exhaust coming out of the joint like I did before.
What's wrong with using stainless in that application? It'll be easy enough to swap in a grad 5 steel bolt and nut if need be, but I've never heard that stainless in an exhaust system was a bad thing.
post #6 of 10 Old 08-19-2007, 08:41 AM
gosupes
Nothing wrong with it, it's just not as strong as treated G5 or G8 bolts. IMO, you don't need much to hold an exhaust flange together so I would leave it alone as long as it's not leaking.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #7 of 10 Old 10-04-2013, 12:57 PM
DoubleDown
1983 CJ7
I'm having this same issue. The down pipe I installed isn't 'sealing' at the manifold. The nuts on the flange can't get tight enough because the studs are stripped.
The studs on my '83 258 are threaded into the manifold, I was wondering if they can be removed without removing the manifold ?
If so, any ideas would be greatly appreciated
DoubleDown is offline
post #8 of 10 Old 10-05-2013, 11:16 AM
DoubleDown
1983 CJ7
When I get home from work today I'm gonna try to remove the studs from the manifold using some PB Blaster a Torch and my new set of bolt extracting socket. Hopefully I can back the studs out and replace them without having to remove the manifold. I'll let know how it goes.
Any suggestions would be greatly appreciated.
post #9 of 10 Old 10-05-2013, 11:37 AM
capt205
1983 CJ7
I swapped the bad studs out for nuts and bolts on my 258 earlier this Spring. Worked great, no leaks, and I've had it loose or off a couple of times since.
capt205 is offline
post #10 of 10 Old 10-08-2013, 03:15 PM
DoubleDown
1983 CJ7
That's exactly what I want to do !
My question was HOW ?
Can it be done without removing the manifold ?
If so, what the easiest way ?
Intake Manifold connected to Exhaust manifold - delete? attworth Jeep CJ Forum 14 01-19-2012 02:51 PM
Replacement intake/exhaust bolts/studs? attworth Jeep CJ Forum 3 06-29-2009 07:18 PM
V-8 Exhaust Manifold jksull Jeep CJ Forum 5 04-06-2009 06:41 PM
Exhaust Manifold Help doeboy99 Jeep CJ Forum 9 09-06-2008 07:49 PM
304 Exhaust Manifold reddog reddog Jeep CJ Forum 1 05-02-2008 09:58 AM
