CJ7 258 to 360 V8 Swap. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ7 258 to 360 V8 Swap.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-09-2014, 09:28 AM   #1
marcaurell
1979 CJ7
Apologize for my bad English but I am from Austria / Europe and write and do not speak often in english.
My Friend and I have also the project v8 conversion on cj7 currently running on.
(see Photos)
Two questions: First, the engine is completely overhauled. But AMC V8 engines mabe should be have a problem with the lubrication of the fuelpump and the Distributor. What should I do? In addition, there will be problems if the oil pump is new and empty, is that true ??
We use the 3-speed T150 transmission The gearbox bellhouse has centered above a hole and when there was a six-cylinder screws (cylinder, this has not, you can simply drill and cut a thread?
One more question what kind of alternator and starter do you recommend (Upgrade)
Fotos: The old Heart:
The new:
The Car:
This Year Christmas Lights:
marcaurell is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 11:26 AM   #2
slomo19er
1983 CJ7
Pack the oil pump with Vaseline or any other petroleum jelly. Or you can prelube the motor which would mean you don't need to pack the oil pump. Remove the distributor. Cut the flat blade end from a very large screwdriver. Just cut the handle off as you'll need the length. You can compare the screwdriver to the bottom of the distributor, should look similar. Look down into the block where the distributor goes. You will see a large flatblade slot. Insert your large cutoff flatblade screwdriver shaft into a 1/2" drill. Spin the sucker CLOCKWISE and watch for the oil pressure to build.
slomo
slomo19er is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 12:12 PM   #3
marcaurell
1979 CJ7
slomo
Thank you very much simple but effective.
Unread 11-09-2014, 01:53 PM   #4
82JeepCJ7
1982 CJ7
When I put an AMC V8 in my Jeep, I did not use the top center bolt. I would not worry about it.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 03:48 PM   #5
roadhog304
1973 CJ5
I always pack the oil pump with vasoline even though I always prime the engine. Make sure you use a 1/2" drill too and not a 3/8 cause you will smoke the 3/8. I am using a gm one wire alt and a stock starter on my 360 with no issues with either one. And thanks for starting your own thread. You will get more personalized responses that way and not clutter up other people's threads with stuff not pertinent to their question.
1973 Jeep CJ5 Amc powered fair weather driver
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 03:49 PM   #6
roadhog304
1973 CJ5
Forgot to add that is a nice organized garage and a clean jeep you have
Unread 11-09-2014, 04:48 PM   #7
hutch1200
hutch1200's Avatar
1979 CJ7
Don't forget to use the 360 flywheel and dampener (at the front of the engine). DO NOT re-use your old flywheel and dampener. These 2 bits are used to balance the whole rotating mass of the engine, and are specific to each engine size.
Also, you will LOVE the results of your work. This jeep should have a lot of power and sound great!
Welcome, good luck (Bon Chance?) and keep the pictures coming!
The only "FINISHED CJ" is the stripped one in a junkyard w/a bent frame.
hutch1200 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 09:21 PM   #8
82JeepCJ7
1982 CJ7
To prime the oil system, I use an old distributor I cut off just below the top. I then use the shaft (with out the gear on it) to en gauge the oil pump. The body of the distributor will fit into the block tightly. I then chuck the shaft up in a drill and pump away.
Unread 11-09-2014, 11:45 PM   #9
marcaurell
1979 CJ7
delete
Unread 11-10-2014, 12:41 PM   #10
marcaurell
1979 CJ7
Another Question: Can i use the stock engine speedometer from the 6 cyl at the 8 cyl engine??
In the Front i use this:
http://www.summitracing.com/int/part...view/make/jeep
and in the rear this:
http://www.omix-ada.com/catalog/prod...category/1500/
I hope this are the right parts.
