CJ5's and OEM center concoles? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ5's and OEM center concoles?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4The Jeep Forum Discount is ON!
Unread 05-01-2013, 09:04 AM   #1
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Did the CJ5 come from the factory with a center console? I'm refering to the plastic ones that came in the CJ7. Thanks
Guy Smilie is offline   Reply With Quote Quick reply to this message
Unread 05-03-2013, 11:50 AM   #2
tacjeep99
Center consoles did not become available until the 77 model year. I know because I bought a brand new 76 CJ-5 and bought the console for it after I saw one in a 77. Saw it in a new 77 "Limited Edition" Golden Eagle CJ-5 sitting on the showroom floor at Earl Kirk AMC Jeep IIRC.
I don't think the center console was standard unless it was part of a decor package or ordered as an option.
tacjeep99 is offline   Reply With Quote Quick reply to this message
Unread 05-03-2013, 04:40 PM   #3
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Thanks for the reply. I don't remeber ever seeing one in the 5. I know the came in alot of 7's. I picked one up yesterday that was out of a 7 ( the plastic OEM type) and it doesn't fit in my 5 (78). I can make it fit by triming the back of the console, maybe. It needs to go back about an inch.
Unread 05-04-2013, 01:22 PM   #4
John Strenk
John Strenk's Avatar
1976 CJ5
That's what i did to make mine fit until i got my Tuffy.
Even the tuffy has some strange mounting for the CJ 5
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 05-04-2013, 06:31 PM   #5
titanjeep
1980 CJ5
I have one in my 81 CJ5. If it fits in an '81, it should fit in a '78.
Air Force Jeep Club - Tail# JF183RV
2003 KJ
1980 CJ5
1988 Wagoneer
titanjeep is offline   Reply With Quote Quick reply to this message
Unread 05-04-2013, 07:40 PM   #6
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
This is the OEM console? The one I have the contors on the bottom of the console don't match the contors of the floor in the 5 unless I trim the back of the console. I hope my explantion is understandable. Other than that I guess you could say it fits size wise. Thanks
Unread 05-04-2013, 08:45 PM   #7
titanjeep
1980 CJ5
Your explanation is good and I think that we are talking about the same thing. Mine is a factory console with the contoured base. Here is a picture of mine (at least the best one I have right now... you can see the front of it under the blanket. I can get some more pictures tomorrow if you think it would be helpful.)
[/URL]
I am surprised that it doesn't fit because I thought the tubs were same between '78 and '81 (minus the different roll bars). Either way, I hope that you are able to get it mounted up the way you want. I know mine is pretty handy and I like the lower profile because it makes it easier for people to climb in the back.
2003 KJ
1980 CJ5
1988 Wagoneer
Unread 05-05-2013, 07:13 AM   #8
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
[/URL]
That's the same console and I think the tubs are the same too. not sure what I'm doing yet. I've got more urgent things to work on first. Thanks
Unread 05-05-2013, 01:59 PM   #9
tacjeep99
I liked having the OEM consoles in my CJ-5 and CJ-7, but I will say the cup holder placement was a bit awkward.
I am not sure, but I thought the CJ 5 console and CJ 7 console were the same length. Are they?
Unread 05-06-2013, 02:20 AM   #10
John Strenk
1976 CJ5
Cant be, I tried the a CJ7 center console in my CJ5 and without cutting it would hit the gear shifter.
I had to cut out a couple of inches on the bottom to make it fit.
Cj5 and CJ7 tubs are not the same, the CJ 7 tub is 10" longer and I think most of that is behind the seats.
Unread 05-06-2013, 05:13 AM   #11
keith460
Jeep. There's Only One
keith460's Avatar
CJ-5 and CJ-7 factory console are the same but the CJ-5 version is cut in the back to go over the rear floor riser. I have seen a few on eBay for sale with the factory cutout awhile ago.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is online now   Reply With Quote Quick reply to this message
Unread 05-06-2013, 05:19 AM   #12
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
There you go. Thanks Keith!
Unread 05-06-2013, 10:03 AM   #13
John Strenk
1976 CJ5
Ah!
Then My cutouts are "Factory"
Sweet.
Unread 05-07-2013, 08:54 PM   #14
tacjeep99
I recall the back of my console for my CJ 5 having cut out now that you mention it.
