cj5 won't stay running - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > cj5 won't stay running
BLACK FRIDAY SPECIALS!! You asked, we deliver!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 11-24-2014, 05:42 PM   #1
doug80cj5
I have a 1980 cj5 with 304 that will start up run but then dies after 20 seconds. When running it will be smooth a few seconds and then run rough as hell and die. Was running fine till last week when I drove to the store and it would hesitate when trying to go over 2500 rpm and on the way back I could barely keep it running. Two months ago I had some electrical issues and had to replace coil, distributor(aftermarket Mallory with no vacuum line), ECM etc.. so I don't think its electrical because it ran perfect since. Fuel pressure is good with newer pump/filter. I can see it squirting pretty good gas into the carb but still wonder if I needs a rebuild or something is up with the auto choke(its open when trying to start). The last time it ran great I was hot rodding it around town pretty good so I guess I could have jumped timing or stretched the chain.. I'm going borrow a timing light and check this weekend. Hoping somebody has been through this before and has advice because I'm tired of spending more time under the hood then on the trails. Thanks in advance.
Doug
doug80cj5 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:47 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Doug,
When the engine is cold, your choke should close fully when you pump the throttle before starting. Then it should gradually open as the engine warms up.
It sounds like your choke needs attention.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:12 AM   #3
CSP
If the timing chain had stretched on jumped a tooth you wouldn't have that smooth 20 seconds of running.
CSP is online now   Reply With Quote Quick reply to this message
Unread Today, 09:43 AM   #4
TIPPEDITOVER
TIPPEDITOVER's Avatar
1978 CJ5
Doug
Timing light will show if there's any ignition problem. If it's flickering all over the place doing weird stuff, then there you go. You could check every plug cable easy enough.
You could have some debris in the carb. Doesn't take much. Or maybe good fuel pressure overcoming a worn/leaky needle valve.
Something is up with the choke, needs attention.
TIPPEDITOVER is offline   Reply With Quote Quick reply to this message
