CJ5 Wiring Harness Identification Questions - Page 4 - JeepForum.com
post #46 of 132 Old 01-08-2013, 04:19 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Are all those black wires ground?
John Strenk is offline
post #47 of 132 Old 01-08-2013, 12:07 PM Thread Starter
2girlsAndaGuy
1979 CJ5
yes
David
2girlsAndaGuy is offline
post #48 of 132 Old 02-05-2013, 03:37 PM
dubya5813
1979 CJ5
going to need this thread soon, 'bout to go through my wiring.....and I'm not very good when it comes to wiring issues....
dubya5813 is offline
post #49 of 132 Old 02-06-2013, 03:54 AM
John Strenk
1976 CJ5
It did get rather detailed didn't it?
post #50 of 132 Old 02-06-2013, 10:17 AM Thread Starter
2girlsAndaGuy
1979 CJ5
yes it did get a bit detailed, what did you think of my many ground wires John? Was there a better way I should have taken care of all the grounds coming off the dash? My plan is to run all those grounds to one ground bus bar and then bring in a large gauge ground wire from the battery to the bus bar. Sound ok?
David
post #51 of 132 Old 02-06-2013, 10:29 AM
John Strenk
1976 CJ5
Sounds OK to me...
post #52 of 132 Old 07-01-2013, 12:32 PM Thread Starter
2girlsAndaGuy
1979 CJ5
well I finally got the jeep running. Most everything is wired up and working with the exeption of a few quirks here and there. Still left to wire in our the new LED tail lights, electric choke, and manifold heater.
One of the odd quirks that I am fighting right now is that two of my gauges on the dash are always lit when the battery is connected. The other 5 + indicator lamps come on as they should when the light switch is pulled out. I have noticed however that the dimmer function on the switch doesn't work very well. I'm wondering if maybe I have a bad switch and that is causing those two lights to always be lit? I can't understand why just these two would be constantly lit, I came off of the orange illumination circuit? Anyone got any idea's.
Another issue I'm trying to figure out is how to wire in the rear tail lights and fuel sender, my new tail lights have the backup lights built in and require two three pin plugs to operate. Each plug has a ground and a red and black wire coming off. Any idea's on how I should wire these up.
Here are a few pictures of my rear harness, it has been hacked on really good...
Name:  trailer hookup.jpg
Name:  trailer hookup1.jpg
Name:  trailer hookup2.jpg
These first three photo's show what appears to be a spliced in set of wires, I haven't been able to track them down in my wiring diagram. Any ideas what they may be for? Trailer hookup possibly?
Name:  tail light hookup.jpg
Name:  tail light hookup1.jpg
Name:  tail light hookup2.jpg
These three photo's show my tail light and side indicator lamp wiring. This is what I need to splice into for the new tail lights I'm just not sure how to go about it.
Also I don't see any wire coming back to the sending unit for the fuel gauge, am I missing something here as well?
David
post #53 of 132 Old 07-02-2013, 05:51 AM
John Strenk
1976 CJ5
How much rewiring do you want to do?
If the harness was in better shape I would cut the leads off my old tail lights and splice them into the new tail lights.
But with the harness in that bad of shape, I may cut back and find some good copper and make a custom harness for the new LED lights.
For your speedo lights, it could be a bad ground to the speedo that is causing something to use the lights in the speedo to be in a ground circuit.
Or the wrong bulbs in the wrong place.
post #54 of 132 Old 07-02-2013, 10:32 AM Thread Starter
2girlsAndaGuy
1979 CJ5
ya that rear harness is really sad looking, rewiring it from a ways back doesn't scare me. Before it drops through the tub it is in pretty decent shape, so splicing in there and re-wiring the lights from that point is probably my best bet. Also right before it goes through the wheel well is where that square plug is spliced in. Any thoughts on what that may be for? If I can just eliminate it from the harness it would be best.
Here is a picture of the driverside tail plug, + what I assume is the fuel sending wire in pink?
Name:  driver side plug.jpg
Now jumping up the the engine compartment, I have 1 wire and two plugs that still need identification.
This yellow wire doesn't have a home yet, any idea's what it is for?
Name:  unknown plugs.jpg
same thing with these two plugs, they were never plugged into anything even before I tore things apart.
David
post #55 of 132 Old 07-02-2013, 10:52 AM
John Strenk
1976 CJ5
Those are for the Dome light if you had one.
Attachment 642029
Yep, Fuel gauge, Were is yours hooked up now?
Attachment 642031
Windshield washer pump???
IS that a water pump in the picture or an air pump for the air horns?
Maybe the PO rewired the pump differently.
Attachment 642032
the Yellow and Orange wires go to Quada track and Kickdown on Automatic tranny
The other one could be for the brake failure switch on the combination valve if both wires are black. Ought to hook that one up.
post #56 of 132 Old 07-02-2013, 11:08 AM Thread Starter
2girlsAndaGuy
1979 CJ5
Ok, do they not show this on the standard wiring diagrams?
It's not hooked up at all currently. I've got it wired in under the dash to the correct wire, just need to make sure that was this one.
It's an air pump for the horn. Rig never came with a windshield washer pump or reservoir.
hmmm, not sure what the brake failure switch on the combination valve would even do. But you are correct both those wires are black
David
post #57 of 132 Old 07-02-2013, 11:15 AM
John Strenk
1976 CJ5
On some they do....
Very sure it's for washer pump
Warns you of a leak in the brake system. Not that being unable to stop not tell you enough....
post #58 of 132 Old 07-02-2013, 02:02 PM Thread Starter
2girlsAndaGuy
1979 CJ5
ok now back to the tail lights, I've put together a simple diagram showing the existing system or rear harness and also my new tail lights. Where I am stuck is connecting the dots between the two points.
If you look at the diagram I made, you will see that I have two wires coming from each light. I ultimately end up with an extra wire on the backup light circuit. Any clue as to what to do with this setup?
Name:  tail light diagram.jpg
David
post #59 of 132 Old 07-02-2013, 09:28 PM
texasdave
texasdave's Avatar
1980 CJ7
Original lights grounded to the body with the mounting studs. If the wire coming from the b/u light is black then it would be a ground wire. With LED lights you also need to wire in resistors unless they are built into the light fixture.
texasdave is offline
post #60 of 132 Old 07-02-2013, 11:01 PM Thread Starter
2girlsAndaGuy
1979 CJ5
The LED lights have a ground wire coming off of both the tail and backup lights as well as the two wires shown in the diagram. 6 wires total.
David
