CJ5 Wiring Harness Identification Questions - JeepForum.com
post #1 of 132 Old 12-26-2012, 10:53 AM Thread Starter
2girlsAndaGuy
1979 CJ5
Ok, hope all had a nice Christmas and got everything on their list.
Over the weekend I've been working on cleaning up and getting my main harness wired back up to my dash and have managed to fumble through a wiring diagram to identify some of the wires coming out of the fuse block but am still left with a lot of questions. I have taken pictures of all the wires I still am unsure of and would greatly appreciate it if you all could help me figure out my unknown plugs.
Unknowns are highlighted with blue.
PICTURE 1 -
Unknown1 : Black/Red Light
Unknown2 : Black off of light
PICTURE 2 -
Known : Quadratrac Light
Unknowns : Red wires coming off of Light
Also unknown is what the quadratrac light is for?
PICTURE 3 -
Unknown1 : Red w/trace plug
Unknown2 : Red w/trace wire off of plug
PICTURE 4 -
Unknown1 : Orange wire
Unknown2 : Red w/trace (this wire the plug is missing)
Unknown3 : Red w/trace + black plug
Unknown4 : Red + 2 gray plug (know that high beam light comes off of this)
Just a shot of the full harness, gives an idea of what I'm working with.
Also I am wiring in autometer gauges, and they all say they require a 12v switched power wire to them. I have located and labeled most of the signal wires to them, and of course grounds will need to be brought to them, but I am still a bit stumped on the switched power. Did the old gauges have this power wire as well?
Sorry for all the questions, but as you can see I'm in way over my head here.
David
2girlsAndaGuy is offline
post #2 of 132 Old 12-26-2012, 11:12 AM
sanmiam
sanmiam's Avatar
1983 CJ7
The old guages did not use a dedicated power (with the exception of the voltmeter and tach). Is the power to the autometer guages for the guages to function, or for the lights? If lights, just run the orange/black wires that are in the stock harness (some do not have a black and grounded to the dash through the brackets - easy enough to run additional grounds)
If they require a 12V switched you can either tap off the lighter, or plug into the radio or clock light/tach light on the fuse box.
As far as your questions above:
Pic1 - looks like a light plug that someone added (common since factory light plugs tend to break the little metal pieces). The red is power from the harnes, the black goes to ground
Pic2 - w/o knowing where in the harness I can't comment
Pic 3 - This plugs into the brake switch. The other side should get power from somewhere - can't remember where.
Pic 4 - Top left goes to rear light harness. Top right I believe is for parking brake. Middle right goes to ignition switch (the one mounted on the steering column under the dash) Red and white wire I am unsure of, and the orange one plugs into the fuse box for the clock light (I am 99% sure anyhow)
Pic 5 - Looks like fun!
If any of my comments are incorrect please don;t shoot the messenger - I am going strictly off memory. If you are REALLY stumped shoot me a PM and we can exchange contact info so I can comment on it while I am looking at my harness. I just went through this a couple months ago so it is fairly fresh on my mind.
Building a Jeep is like playing golf, every now and then you get a good shot that makes you believe, hey I can do this!
sanmiam is offline
post #3 of 132 Old 12-26-2012, 11:59 AM Thread Starter
2girlsAndaGuy
1979 CJ5
Thanks for the reply, I have updated a few of the photo's to show your comments. I also added another photo for more identification.
Updated with comments from sanmiam
PICTURE 5 -
Unknown1 : Red + White plug
Unknown2 : 2 Yellow plug
Unknown3 : Red w/stock plug
Unknown4 : Red w/non stock plug
David
post #4 of 132 Old 12-26-2012, 12:53 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Attachment 531319
PICTURE 1 -
Brake warning light
and the other one goes to your Parking/Emergency brake. Just one wire.
Attachment 531320
PICTURE 2 -
Quadratech light is to indicate your in 4 WD. It is controlled by a switch ether on the Dana 300 or off the Automatic with Quadatech
Attachment 531321
PICTURE 3 -
For sure brake switch with someones new power feed because the other end goes into the TS plug.
Attachment 531322
PICTURE 4 -
Orange is usually some type of illumination circuit light for the dash light. Since it is separate from others I would hazard a guess it's for the head light switch indicator. The one above the head lifght switch or possibly for the PRNDL if you have an automatic.
Red is usually power whether switched or on all the time.
They can go to radio, brake light switch. (maybe that is why one is cut off and a new wire added to the brake light plug. Does the length match up?)
Attachment 531323
John Strenk is offline
post #5 of 132 Old 12-26-2012, 01:01 PM
John Strenk
1976 CJ5
Attachment 531359
Parking brake is wrong, should only be 1 wire.
Need a close up
Attachment 531360
Attachment 531361
PICTURE 5 -
On 1 and 2:
Do you have an automatic tranny?
The red and white and Yellow ones are used for the Automatic tranny.
3 and 4 :
Could be used anywhere.
post #6 of 132 Old 12-26-2012, 01:24 PM Thread Starter
2girlsAndaGuy
1979 CJ5
Brake warning light
When parking brake is engaged?
I have a Dana 20, would this light still apply?
TS plug?
Manual transmission, I'm getting clearer on the orange wires however. All are for dash illumination.
The red wire that is cut is a red with white line. Does that matter?
comments in the quote.
David
post #7 of 132 Old 12-26-2012, 01:26 PM Thread Starter
2girlsAndaGuy
1979 CJ5
Need a close up
On 1 and 2:
3 and 4 :
I have a manual tranny.
Ok so now if I'm understanding correctly, a solid red is a power wire to feed just about anything. No way to determine if switched or not without being wired up I assume?
David
post #8 of 132 Old 12-26-2012, 01:29 PM Thread Starter
2girlsAndaGuy
1979 CJ5
Need a close up
Here is the best close up of this plug I have...
David
post #9 of 132 Old 12-26-2012, 04:05 PM
sanmiam
sanmiam's Avatar
1983 CJ7
Mabye the other side of the ignition harness? There are two pieces with individual connectors that fit together to plug into the switch.
sanmiam is offline
post #10 of 132 Old 12-26-2012, 09:12 PM Thread Starter
2girlsAndaGuy
1979 CJ5
I think that it plugs into the column somewhere but it's not one of the two that plug in together.
David
post #11 of 132 Old 12-27-2012, 03:09 AM
John Strenk
1976 CJ5
Originally Posted by John Strenk
Brake warning light
Yes, when the parking brake is engaged
Not used on the Dana 20 just extra stuff but keep it in case you install a dana 300 later.
TS plug?
Turn Signal Plug
post #12 of 132 Old 12-27-2012, 03:19 AM
John Strenk
1976 CJ5
Attachment 531388
The light is a dead giveaway, It's for the dimmer switch on the floor.
The light is the hi beam light in the speedo.
yours probably lost the hood but here is the other side of the plug:
Even the wire colors match up.
What is on that tag?
post #13 of 132 Old 12-27-2012, 03:28 AM
John Strenk
1976 CJ5
Here are the two plugs for the ignition Switch:
And what they do...
post #14 of 132 Old 12-27-2012, 03:37 AM
John Strenk
1976 CJ5
About the other wires.
Have an ohm meter?
Ohm these out back to the fuse box. It may be one of them is power for the Fuel gauge.
Need to take fuses out though otherwise it will look like it connects everywhere.
You can tell a lot by were it originates in the fuse box...
I'm thinking you still need to locate
1. Power to Wiper switch (Red)
2. Power to Heater Switch (Tan)
2A. Resistor Pack
3. Horn relay socket
4. Power to Fuel Gauges. (red)
5. That yellow wire you tagged as wiper switch actually goes to the washer pump from the wiper switch.
6. Power for Voltmeter (yellow)
7. Power for Oil Pressure Gauge (red)
8. Sensor for Oil Pressure Gauges.
9. Sensor foe Fuel gauge (Pink)
10. Sensor for Temp Gauge (Violet)
1. Wiper power (Red) with Dash Light (Orange) and washer pump connector (Yellow)
2. Power to heater switch:
6. Volt and Oil connectors
2A. Resistor pack for heater switch
post #15 of 132 Old 12-27-2012, 10:36 AM Thread Starter
2girlsAndaGuy
1979 CJ5
Tag says Hi beam light. Now that you mention that hood, I remember pulling a haggard looking thing off of that plug. Must have been the old hood.
David
