Cj5 Weight? - JeepForum.com
post #1 of 11 Old 03-07-2008, 11:53 PM Thread Starter
Darryl
1987 YJ Wrangler
Cj5 Weight?
What is the weight of a CJ5 equipped with AMC V-8, manual trans, interior roll cage, soft top and soft doors?
Darryl is offline
post #2 of 11 Old 03-08-2008, 12:17 AM
jeepskate
Varies...different year ranges (just like the lengths), different trannies, roll cage isn't stock, just the sport bar. Lotta variables there to try to give you a pat answer.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 11 Old 03-08-2008, 08:36 AM
Happy Joe
My '81 with, stock interior, 33x12.50s, soft top 4 spd and 258 weighed 3600 and change (with winch).
Find a junk car recycler, or recycling yard (good place for raw material, I do a lot of shopping there) and see if they will weigh yours for free. The usually will. If not do some clean up and bring them a load, they will weigh your vehicle full then reweigh it empty to calculate the weight of scrap, just ask for the weights.
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
post #4 of 11 Old 03-08-2008, 10:13 AM Thread Starter
Darryl
1987 YJ Wrangler
Enjoy!
WOW! That is hard to believe. How can it be that heavy? I have a 1969 Dodge Coronet 440 six pack Super Bee with 117" wheelbase that only weighs 3800 lbs. with all standard factory equipment.
Darryl is offline
post #5 of 11 Old 03-08-2008, 10:51 PM
jp360cj
1977 CJ7
Darryl...you'd be surprised at how much weight the 4wd adds. Also, I believe 3600 is about the weight of a stock LT1 camaro, just to put it in perspective
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #6 of 11 Old 03-09-2008, 01:33 PM
Happy Joe
Yep! it suprised me too!
Of course the 258 is probably as heavy (or nearly) as a 440. (I was hopeing for something around 1000 pounds less, overall).
(That includes my lard err, large A** @ 220 lbs).
Enjoy!
post #7 of 11 Old 03-09-2008, 07:05 PM
Project76
1976 CJ5
I have a 1976 all original same specs as you listed and my Title says 2800
Project76 is offline
post #8 of 11 Old 03-09-2008, 11:27 PM
Trapshooter
Darryl,
Find a closed road side truck scale and weigh your rig. Here in Oregon they are all over the place because the state can't afford to keep them all open. The state rotates the DOT guys around to keep the truckers guessing.
Most of the scales here will still read even if its closed.
Love Sedona, one of my favorite places.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #9 of 11 Old 03-10-2008, 09:09 AM
Cherokeester
Cherokeester's Avatar
1980 CJ7
Semi equipped TJ's come in around 4300 lbs. My CJ7 is just under that and my Cj5 is just under that at 3900 lbs.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
post #10 of 11 Old 03-10-2008, 09:11 AM
algmmech
1974 CJ5
last summer I weighed mine at the local dump. with both me and my wife in it with all the gear and about half a tank of fuel. It weighed in at 3220. I didn't have a winch at the time. So the cj5 empty should weigh in about 2900 lbs. Now my jeep doesn't have a boxed frame and rust doesn't weigh much.
mostly stock 74 cj5, 258, t14, d20, d44 & 30.
I'm a member of PETA.
People Eating Tasty Animals
algmmech is offline
post #11 of 11 Old 03-10-2008, 09:43 AM
Happy Joe
Early 5s will weigh significantly less than later 5s due to the light weight v-6 (the I-6 used in later 5s weighs more than some v-8s) the early 5s also have lighter (unboxed, as mentioned above) frames and a lighter roll bar (if equipped). the front clip and frame on the early 5s is also shorter. The later 5s have a heavier belly pan and gas tank/skid plate.
There are undoubtedly other differences (like the flip forward seat brackets, fancy tailgate and rear seat, if equipped) that add weight to the later 5s.
Enjoy!
CJ5 weight VACJ5 Jeep CJ Forum 3 03-04-2009 03:10 PM
weight ???? jdr821 Jeep CJ Forum 6 12-07-2008 10:11 AM
Tub weight ? RoostrRiz Jeep CJ Forum 1 01-01-2007 04:09 PM
oil weight pf1130 Jeep CJ Forum 7 10-05-2004 09:25 AM
What oil weight to use in new 258? cw05 Jeep CJ Forum 2 07-17-2004 05:46 PM
