CJ5 trans loose shifter - JeepForum.com
post #1 of 4 Old 01-30-2009, 09:01 PM Thread Starter
foxracer677
1974 CJ5
So im finally going to get get to start messing with my CJ5 this weekend after working non stop this past week. I was wondering what would cause the transmission to pop out of first gear, only sometimes. If i hold it down it will stay in, but rattles out it i just try to put it in and leave it there. Only sometimes though. The transmission has ALOT of play in the shifter, Any way it could be something like a loose shift linkage/bushing shot? or am i in for a total rebuild.?? Thanks
foxracer677 is offline
post #2 of 4 Old 01-31-2009, 08:06 AM
sgtbookie
Which trans do you have in your '5? I know on my T-176 Crown makes a $20 shifter repair kit that tightened mine up nicely.
2005 LJ Rubicon Sahara #380
sgtbookie is offline
post #3 of 4 Old 01-31-2009, 11:58 AM Thread Starter
foxracer677
1974 CJ5
its a '74 so im thinking is the t-14, 3spd.
post #4 of 4 Old 01-31-2009, 04:13 PM
mcurcio1989
1976 CJ7
I had the same problem with my t150 only it was with second. Your problem is definately with the linkage. I rebuilt mine and replaced the synchro rings and the shift fork. For me the problem was that the shift fork was worn and not fully engaging , hence causing it to pop out and causing premature wear on the synchro rings. Obviously any sort of play will cause a similar problem. Here is the thing the more you drive it like that it will wear the shift fork down and get progressively worse. Trying to "hold" it in causes the fork to rub against the sleeve and this causes even more wear on the fork. You should be able to remove the transmission control assembly, if your t14 is anything like my t150, very easily. Check for wear on the fork because you probably will want to replace it while you are working on the rest of your linkage. I am positive the reason my transmission was doing that was because of the shift fork. I am not a Transmission expert by any means but replacing the fork may save you a lot of time and money. Hopefully you should be able to fix your problem fairly inexpensively and easily. From my understanding it is very likely that an entire rebuild will not be necessary at this point.
mcurcio1989 is offline
Loose shifter handle fix-it kit? Renegade887 Jeep CJ Forum 8 05-25-2010 02:13 PM
SR4 - loose shifter wkp Jeep CJ Forum 4 01-21-2010 04:00 AM
84 CJ-7 Loose Shifter-which trans??? andrewferin Jeep CJ Forum 2 04-12-2009 07:51 PM
Loose TC shifter bdub Jeep CJ Forum 2 03-30-2006 01:54 PM
Loose Shifter on CJ7 mike.clubb@hotm Jeep CJ Forum 3 01-18-2006 11:17 AM
