CJ5 Trail rig Build w/ Pics - Page 3 - JeepForum.com
post #31 of 85 Old 08-05-2010, 11:49 AM
78treehugger
1980 CJ7
I use a set of 2" of E-bay. I haven't had any trouble after I retorqued them. I used blue loctite also. The opposite wheels started wobbling on the trail. I pulled both wheels and the lugnuts came loose. I then realized I didn't retorque after my fist trip. After I torqued them down and then retorques them after the trip I haven't had troubel since. They have been on mutliple trips also. Trails and rocks and some short back road trips. As long as you check them you should be alright. Mine are tempt fix until this winter (if all goes according to plan).
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #32 of 85 Old 08-05-2010, 02:16 PM Thread Starter
crzdmnky
1978 CJ5
So is it almost cheaper to buy 2 wheels for the front that have an extreme offset? Or is it better to go with the wheel spacers?
crzdmnky is offline
post #33 of 85 Old 08-06-2010, 10:00 PM
mxracer919
1979 CJ7
Get that axle in there yet? I know a guy with a geared and locked widetrack that will solve your front end problems........just sayin, lol
mxracer919 is offline
post #34 of 85 Old 08-08-2010, 02:56 PM Thread Starter
crzdmnky
1978 CJ5
Ok I give, so what do you want for it?
But no I havent gotten the rearend in yet. Trying to get the dumb transmission in still. The pilot bearing has a small hole, and I cant seem to get it in it for some reason. Its really annoying, spend all of last night till 5 in the morning trying to get it in. I only have a couple of inches to go.
crzdmnky is offline
post #35 of 85 Old 08-08-2010, 05:39 PM Thread Starter
crzdmnky
1978 CJ5
With a 4" suspension lift. Do you need a drop pitman arm and High Steer in conjunction. OR do you just need one or the other.
AND Can I get some pics of the way you guys reinforced your Steering boxes?
Also, let me know how 33 x 12.50 tires and manual steering is while on the trails and what not.
crzdmnky is offline
post #36 of 85 Old 08-09-2010, 02:45 PM Thread Starter
crzdmnky
1978 CJ5
Can no one answer my questions?
crzdmnky is offline
post #37 of 85 Old 08-09-2010, 02:54 PM
Chewtoy
1976 CJ5
I just have a tierod flip on mine and it works fine. I can get pics tonight if you wana see.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #38 of 85 Old 08-09-2010, 03:05 PM Thread Starter
crzdmnky
1978 CJ5
Well, I believe you, just there is, like most other things, an argument about if it works or if it doesnt. I think it would, just dont want to go dump $45, and then turn around and have to dump another chunk.
crzdmnky is offline
post #39 of 85 Old 08-09-2010, 07:19 PM Thread Starter
crzdmnky
1978 CJ5
So an update on whats going on with the CJ5. I got my SM420 installed today along with the transfercase. I do not have my skid plate mounted yet because taking my previous one off I broke off every single bolt. What I am going to do is drill all the way up through the frame and tub, and insert a long grade 8 bolt.
After that is finished I am going to install my AMC 20 that I just picked up ( pics coming). Its a widetrack AMC 20 with Warn Full floating axles, lockout hubs, and a Detroit locker. When I am installing the axle the 4" Superlift super ride springs are going on as well, as one whole unit.
As far as the Front goes I have some fab to do and money saving to do. My front is just a narrow track Dana 30. nothing special...yet... But I am going to buy some 1.5" spacers, and get the goferit bushings to flip the steering. Then I am going to weld some shock mounts on to the axle. Probably go with something like this http://www.ruffstuffspecialties.com/catalog/paired-bracket-175tube-p-30.html. Afterwards, I acquired a set of what appears to be aftermarket upper shock mounts that are made out of square tubing and are longer, and I am going to mount them on the front. Then all there is left to do is find some front shocks.
I recently got me a Set of MT 35" Baja Claw tires. Pretty well worn, and they dont sit anywhere near 35", more like 33", but should work for now till I get all the bugs worked out and I get some more money saved. This is why I asked how does a CJ5 steer with manual steering and 33 x 12.50 tires.
After all this major drivetrain and drive line work, I can start on body armor and paint, cant wait!
Will have some pictures of the transmission in the jeep and my new wheels and tires. Then I will get some before, during and after of the lift and axle installs. Should all be happening this week. Unless of course something goes terribly wrong.
crzdmnky is offline
post #40 of 85 Old 08-09-2010, 07:40 PM Thread Starter
crzdmnky
1978 CJ5
I updated the first post with my specs as she sits, and other things like some links to info that I am using (this list is sure to grow as I think of things).
crzdmnky is offline
post #41 of 85 Old 08-10-2010, 08:26 PM Thread Starter
crzdmnky
1978 CJ5
Heres some pictures of what I have been doing.
Heres my new to me tires... Still wondering how the manual steering will be with that wide of a tire.
Heres how I am going to install my Crossmember on the transmission. I just drilled all the way thru the frame, and install 7" long grade 8 bolts with a nylon lock nut.
This is my AMC 20 with full floating axles, and rear 4" lift springs already installed. Very excited to get this thing installed.
crzdmnky is offline
post #42 of 85 Old 08-11-2010, 08:44 AM
LSUtiger
1980 CJ5
I had 33x12.50 tires with manual steering when I got the jeep. It sucked! The steering column was getting loose. Almost impossible to turn at a dead stop. I would highly recomend power steering.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #43 of 85 Old 08-12-2010, 05:34 PM Thread Starter
crzdmnky
1978 CJ5
Got some new pics today off all the work I got done today. Got the old axle and springs out, and installed my 4" lift springs, and Widetrack AMC 20.
Just finishing up getting the springs up and shackles on, and starting on the brakes.
All Done! I cant tell the difference...
The Other side....
< Here is a Before pic >
Tomorrow, if the GF lets me, I am going to install the front lift springs.
I definitely need them 1.5" wheel spacers for the front now, other wise it just looks goofy with that wide track in the rear.
1977 CJ5 - 37" military humvee tires/wheels - SM420/Dana 300-4" Alcan lift-AMC 20 w/ Full floating axles,Locking hubs, Detroit Locker-D30 w/limited slip
crzdmnky is offline
post #44 of 85 Old 08-12-2010, 05:55 PM
Skerr
X2... they don't call it "Armstrong" steering for nothing!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #45 of 85 Old 08-12-2010, 06:20 PM Thread Starter
crzdmnky
1978 CJ5
Will I need shims on the front w/ a 4" suspension lift?
And since I am not running a widetrack axle, am I going to have problems with the brake calipers hitting the front shocks?
crzdmnky is offline
cj7 build, pics dirtdonthurt Jeep CJ Forum 19 10-19-2012 08:30 PM
Drivetrain Build Advice Trail and Second vehicle use, for now Woolys_CJ7 Jeep CJ Forum 1 10-20-2009 12:33 PM
76 CJ build up with pics ONEMORE2 Jeep CJ Forum 18 01-05-2008 06:09 AM
Trail CJ build ?'s this is long but I like to get others ideas. texascj77 Jeep CJ Forum 13 09-20-2007 09:21 AM
Trail pics Skitz Jeep CJ Forum 3 09-29-2003 10:05 AM
