CJ5 tanny - JeepForum.com
post #1 of 7 Old 01-05-2002, 04:09 PM Thread Starter
vulcan
Post CJ5 tanny
howdy y'all. i just foung this forum and decided to becom a member. i just reciently bought a '71 CJ5. i bought it lifted with big ole tires on 'er. so the first thing i did once i got 'er runnin was take it on out back and go muddin. to make a long story short i stripped out first gear in the tranny along with the first idler gear. my question is: does anybody know where i can find cheap jeep parts. i am in high school so i have a limmited ammount of cashflow. the cheapist price i got was $500. thanks in advance
if at first you dont succeed, skydiving is not for you.
vulcan is offline
post #2 of 7 Old 01-05-2002, 04:21 PM Thread Starter
vulcan
Post
its a t-19 tranny btw
vulcan is offline
post #3 of 7 Old 01-05-2002, 08:57 PM
Darko
Post
the t-18 and t-19 trannys are hard to find. If I were you I would look around for a bench top rebuild, it shouldn't run more than a few hundered bucks. As for the parts, they are out there you just need to look.
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #4 of 7 Old 01-05-2002, 09:10 PM
Knucklehead
1973 CJ5
Post
If you're in the south east I recommend you call James Newsome in Statesbore GA. He's got a great collection of parts jeeps at his farm. Last time I was there it was mostly older stuff (flat fenders and early CJ5s). He'll send stuff out too. I misplaced his business card but a directory search came up with (912) 587-5918. Try him.
WJ Build: http://www.pirate4x4.com/forum/jeep-cherokee/2171458-wj-build-sd-axles.html
Knucklehead is offline
post #5 of 7 Old 01-06-2002, 11:55 PM
RockJeep
Motobilt.com
RockJeep's Avatar
Post
is this tranny the stock one that came in it? or was it swapped in? if its stock its not a t-19 but rather a t98 or t150. is it a 3 or 4 speed? does it have a granny gear? i.e 6.32:1. if its a t98 you could probably find a used one for cheap and just swap it out. check out www.4wd.com for bearings, seals, etc, i think they can get gears and other hard parts too.
1998 Jeep TJ on 37's, locked, long armed etc
Sales Manager at
RockJeep is offline
post #6 of 7 Old 01-13-2002, 03:08 PM Thread Starter
vulcan
Post
thanks guys. its a 3 speed i think it is stock and it has got granny gear.
vulcan is offline
post #7 of 7 Old 01-13-2002, 05:52 PM
Knucklehead
1973 CJ5
Post
What engine is it mated to? Probably a T-90 although the T-86 and T-14 were available in the 71s also. Make sure you get the casting numbers off the tranny and properly ID it before you order parts.
Dana 20 t-90 Tanny Cannawilly Jeep CJ Forum 1 08-17-2006 03:38 PM
