cj5 steering wander - JeepForum.com
post #1 of 7 Old 03-15-2015, 03:55 PM Thread Starter
dons76
1976 CJ5
cj5 steering wander
hey gang I have read all the sticky on this subject and at this time I cannot measure the caster angle but I do have a question. My jeep is 1976 cj5 with a 304 the suspension is stock except for a shackle reverse kit on the front end. I have a fiberglass body on it, do you think that the weight of the body is a lot lighter could this cause the caster angle to change? I also have 12x33 tires. thanks don
dons76 is offline
post #2 of 7 Old 03-15-2015, 04:47 PM
AKjeff
1974 CJ5
Is the steering wander new? Did it start after doing any work on the Jeep, or has it done it since you bought it?
My CJ5 had a bad wander when I bought it. Adjusting the steering box didn't help but adjusting the wheel bearings did.
AKjeff is offline
post #3 of 7 Old 03-16-2015, 02:25 PM Thread Starter
dons76
1976 CJ5
It has had the wander since i got it.the only front end work i have done is the shackle reversal,the wander wasn't as bad with the stock tires but i a lot worse with the larger tires the last time i checked the front end components were all tight.
dons76 is offline
post #4 of 7 Old 03-16-2015, 04:18 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Chances are good that the reverse shackles reduced your caster angle, and the larger tires compounded the problem.
Matt
Matt1981CJ7 is offline
post #5 of 7 Old 03-16-2015, 05:25 PM
WindKnot
1977 CJ7
I agree with Matt. The tub weight shouldn't really be a factor.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #6 of 7 Old 03-16-2015, 06:31 PM
jeepwhore
If the shackle reversal put the shackle hanger eyes below the frame (rather than passing through the frame) it won't reduce caster......it will increase it.
What kind of tread is left on the bigger tires you put on?.....wider tires with low tread have more of a tendency to follow ruts I the road surface.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #7 of 7 Old 03-16-2015, 06:47 PM Thread Starter
dons76
1976 CJ5
the tires have most of the original tread on them as I haven't driven the jeep to much.i would like to thank all of you for taking the time to answer my question when all this snow melts I will be able to get to the jeep and then measure the caster.
dons76 is offline
