CJ5 Starter Issue - JeepForum.com
post #1 of 3 Old 07-13-2003, 01:13 PM Thread Starter
canuk01
Question CJ5 Starter Issue
I have a 1978 CJ5, the starter solenoid failed and I replaced it with a new one. The issues is that the solenoid will not work. If I apply 12V from the battery it engages. I measured the voltage that is coming to the solenoid and it reads 12v. It's not a ground issue on the solenoid. Could there be a voltage drop somewhere in the ignition circuit?
HELP
canuk01 is offline
post #2 of 3 Old 07-13-2003, 04:46 PM
fuzz401
1978 CJ7
on the sol you have 2 post in the middle s = switch and I = ingition see if you are getting voltage at the s terminal if not back track the wiring to find were you are losing it it is a lt blue wire and ck under the dash for a plug that has a jumper in it it is the neutral safity switch if the plug is not in it will not start eather then to ing switch it self
and make shur the sol is grounded good the case is the ground for the sol
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 3 Old 07-13-2003, 04:59 PM Thread Starter
canuk01
Thanks Fuzz401...
I do have 12v at the blue wire, but it will not activate the solenoid. If I connect a wire to the '+' terminal of the battery to the selenoid it will activate.
Thats my issue, the blue wire from the ignition (which shows 12V when I put the key switch in start position) will not activate the solenoid. If the blue wire delivers the 12V could there be some loss that makes it to weak at the solenoid?
Very puzzling to me?
canuk01 is offline
Starter problems - starter stays engaged KGBnumber1 Jeep CJ Forum 9 11-13-2014 12:10 PM
Need some Starter / Starter wiring help please! SparkyCJ7 Jeep CJ Forum 14 09-09-2009 06:27 AM
CJ Issue Stalling Issue dcarlton Jeep CJ Forum 3 07-16-2007 02:12 PM
Wierd Starter Issue Tuners Jeep CJ Forum 6 03-17-2007 11:45 AM
304 Starter ? Fudd Jeep CJ Forum 3 09-02-2006 08:12 PM
