CJ5 rear end ringing under load. dana 44 - JeepForum.com
post #1 of 3 Old 01-10-2010, 10:28 PM Thread Starter
Darthteddy
1955 M-38
Wheeled the willys this weekend and ended up with a sound coming from my rear end. Sounds almost like an old telephone ringing. Comes under load and turning and is RPM dependant.
I thought I ripped up my rear end, but upon pulling the cover there was no metal shavings in the fluid and the detroit looked to be in good order. The ring gear appeared to have normal and even wear but I didn't have a light to look at the pinion.
Could be a rear axle shaft maybe? The left rear wheel has about 10* play in each direction before the other wheel starts spinning. I'm just hoping I didn't eat my pinion or locker somehow.
55 cj5 willys. Dana 18 x-case, 44 rear end(passanger side drop), detroit locker in the rear. 30 front end, locked. 5:38 gears. 33 inch super swampers. Buick 231 motor with some work done to it, turbo 350 automatic tranny.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #2 of 3 Old 01-11-2010, 04:22 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
If your happy with the rear, I would check the driveline. Inspect the U joints, slip joint, the driveline itself for dings or missing balancing weights, the t case output yoke for wear/end play or anything else you can find that may cause a harmonic vibration.
jeepdaddy2000 is offline
post #3 of 3 Old 01-11-2010, 07:57 AM
Mike Romain
Tail pipe hitting?
Mike
Mike Romain is offline
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
rear dana 44 mcktiger Jeep CJ Forum 9 10-06-2008 10:48 AM
rear end popping under load cjclay Jeep CJ Forum 6 11-23-2007 05:16 PM
Dana 44 Rear Jeff5886 Jeep CJ Forum 3 07-09-2007 04:26 PM
Dana 30 Rear End lrsmithwhaley Jeep CJ Forum 10 01-09-2006 07:33 PM
