Quantcast CJ5 questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ5 questions
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 12-05-2008, 05:46 PM   #1
1bad92yj
CJ5 questions
Ok, I've had this 79 renegade for about a half a month now and have worked up some questions. If you can answer any of them, I'd appreciate it.
1. Bolts, where do I get bolts from, like the bellhousing bolts, the clutch bolt, etc.
2. I'm getting a new clutch because im dropping in an amc 360, is there a certain size needed?
3. I just got a different filter to go on the top, the hose coming from the old one went to the oil cap, since that hose isnt need anymore, does that hole in the oil cap need to be plugged off?
1bad92yj is offline   Reply With Quote
Old 12-05-2008, 05:56 PM   #2
Nate97xj
1997 XJ Cherokee
Not sure about the bolts or clutch, but the hose coming from the oil cap is your breather hose. Your Autoparts store should have a filler cap that has a breather built into it. They are cheap, but you don't want to just block off that breather...
Nate97xj is offline   Reply With Quote
Old 12-05-2008, 09:31 PM   #3
kappa505
1980 CJ5
You need to get the right grade of bolts, thread size and length of bolts that came off of the original. Most bolts have markings on the head to let you know their grade, like three dashes or something of the sort. Depending on state laws, you might be able to find the right grade, thread and size at a hardware store. In NM hardware stores don't want the liability of selling grade 8 automotive use bolts, couldn't even get them at the bolt store. Bolts are designed to handle specific torques, and uses. Some of them have smooth shafts before the threads start, some need washers, ect. I always take one that I need with me to the store, makes it easier.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge
kappa505 is offline   Reply With Quote
Old 12-05-2008, 09:41 PM   #4
1bad92yj
I would take one to the store to match it up but I dont have any to take.
Old 12-05-2008, 10:13 PM   #5
turnabout
1974 CJ5
My T15 bolted to the bell housing with 7/16 course grade 8 bolts -- not sure of the length. I'm sure you have a different bell and transmission. Easiest thing to do would be to take the bell housing to your local Fastenel store (you have two in Chattanooga) and size things up. As for length, figure out the thickness of the transmission flange and the depth of the threads in the bell and subtract about a quarter inch after washer and lock washer (you don't want to bottom-out and strip the threads in the bell). As for the bolts from the bell to the block.....find a bolt you have that is close and take it with you and go up or down in size and purchase a few bolt sizes close to what you think you need, go home and narrow it down......it's a pain but easier than taking the block with you! I'd bet something else attached to the block has the same threads and could be used for a reference as well.
Good luck!
The two best off-road vehicles in the world -- the Jeep CJ and rental cars.
turnabout is offline   Reply With Quote
Old 12-05-2008, 10:21 PM   #6
1bad92yj
I think ima take the block to them lol, j/k. Thanx for the suggestions, I need to get a bellhousing first though lol
Glock Forum
