cj5 motor id? 232 or 258? - Page 2 - JeepForum.com
post #16 of 17 Old 04-15-2013, 07:24 PM
ardis8500
1976 CJ7
In all the years that I've been a jeep owner, I've never done this. Great info!
Mine is 211C28 which decodes as a 2 bbl 258 built on November 28th, 1978. That makes a lot of sense now since it has a remanufactured tag on it.
The motor came in my 1976 CJ-5 that I had and had the T-150/Dana 20 combo behind it. I swapped in a T-18a later. If I decoded the CJ-5 VIN, it showed a 232.
Now on my 1976 CJ-7, which I purchased in pieces, the VIN decodes as having the 304 V8 with auto and quadra-trac, which wasn't there when I purchased it. The frame and body had seen its better days on the CJ-5 so the entire drivetrain, axles and suspension were moved to the CJ-7. Oh yea, I also swapped in wide-track axles from an 82 scrambler as well on YJ springs.
Thanks for posting! Learn something new every day!
1976 CJ-7 (resto-mod), YJ "family" cage, 6" YJ Springs, 35" BFG MT's, Warn 8274, 258, T-18a, D20, WTD30 & WTAMC20, 3.54 gears & locked F&R.
ardis8500 is offline
post #17 of 17 Old 04-15-2013, 09:06 PM
EgulAye
1980 CJ5
Look here
Originally Posted by Stephen84 View Post
Im confused the code on mine is 11CL10 can anyone tell me what engine i have please
There are several older threads here on the forum regarding engine codes. If you read this thread you should end up with links to other threads and pages to find your code:
http://www.jeepforum.com/forum/f12/e...number-748501/
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
would like to replace 79 CJ7 motor with Ford motor alisa65 Jeep CJ Forum 6 05-05-2009 09:44 AM
will this motor fit in my 77 cj5????? flynn25 Jeep CJ Forum 3 11-20-2008 05:17 PM
Ok, so, what's the best all around motor? TheJunkMan2005 Jeep CJ Forum 9 05-14-2006 09:07 PM
cj motor swap but what motor need help flip2spin Jeep CJ Forum 3 01-21-2004 07:11 AM
150 motor to a 304 bowlsy23 Jeep CJ Forum 4 09-02-2003 05:33 PM
